Old photo location (Cumbria?)
D1537
11 Jul 2019
Hello all, clearing out some stuff from an empty house after a death and wondered if these photos could be identified? I don't have a date, though they were with some other photos dating from the early 60s. The only thing I have to go on is that the deceased's relatives worked on the railways in the 50s and 60s, but I don't have a location apart from the fact they were from the Lake District. The 2nd photo appears to be taken from the cab of a dmu similar to that in the first photo, so I'm guessing they're in the same or similar location, but that's just a guess.
Gloster
4 Sep 2020
Up the creek
I think the lower one is Bassenthwaite Lakeand the upper one probably is too, but I will keep on delving.
Rescars
25 May 2021
I'm afraid I can't help with the location, though the cutting looks quite distinctive. From what I can deduce from the second photo, the position of the points suggest that the train has just left the station and the photographer was in the rear cab. The signalling implies that there was an up and a down side to the loop rather than it being worked as an up-down main and relief - so not aligned for fast through running. The platform lighting in the first photo is delightful - presumably late night crowds were not anticipated. What a shame the photographer didn't take a snap of the other side of that running-in board!
D1537
11 Jul 2019
Thank you both. I have found another one - appears to be the same station as the first photo looking at the hedge - and this time we have a destination blind of Penrith, which would fit with Bassenthwaite Lake?
Deepgreen
12 Jun 2013
Betchworth, Surrey
I'm afraid I can't help with the location, though the cutting looks quite distinctive. From what I can deduce from the photos, the position of the points in the second photo suggest that the train has just left the station and was taken from the rear cab. The signalling implies that there was an up and a down side to the loop rather than it being worked as an up-down main and relief - so not aligned for fast through running. The platform lighting in the first photo is delightful - presumably late night crowds were not anticipated. What a shame the photographer didn't take a snap of the other side of that running-in board!
Yes, this looks like the late '50s/early '60s, and station lighting then didn't have to meet modern CCTV-driven levels. Of course, as films of the era showed, even pitch-black nights looked bright enough to read by!
Gloster
4 Sep 2020
Up the creek
It definitely seems to fit. The destination blind is actually at the rear of the train, but that would be the front when heading for Penrith. There are plenty of photos of Bassenthwaite Lake on the .disused-stations.org.uk site.
D1537
11 Jul 2019
Yes, the images at that website definitely fit the station buildings! Thanks for your help.
Rescars
25 May 2021
A trivial, or perhaps not so trivial, point. I can't see a tail lamp on the train. Were these carried on a lamp bracket, or was one of the fitted lights (central one below the cab window?) used to display a red light, as became common practice with Southern emus? In a mechanically signalled area, a separate tail lamp was presumably easier for signallers to spot and be assured the train was complete before they belled train out of section.
Gloster
4 Sep 2020
Up the creek
Yes, I noticed that: I spent seven years looking for tail-lamps. It may have been that early on the units own inbuilt lights sufficed, although later a tail-lamp was normally fitted, or they might just have detached a second unit and not fitted the new lamp, or they might have simply forgotten, which is particularly possible if it was one of the odd workings that started at Keswick.
Rescars
25 May 2021
I hope there wasn't meant to be a parcel van or similar, which had become detached mid-section!
Gloster
4 Sep 2020
Up the creek
There is at least one photo on the disused-stations site where the unit does not appear to have a tail-lamp. My guess is that when the DMUs were first introduced a red shade was placed over the marker lights to act as a tail-light, but within a few years it was felt either that the light was too weak or there was risk that an electrical problem would mean that a train had no tail-light, so old-fashioned lamps were to be fitted. A look at the .railcar.co.uk suggests that, if this is correct, the rule would have been changed by 1958.
High Dyke
1 Jan 2013
Yellabelly Country
I would concur with it being Bassenthwaite Lake. There is a photo on the Cumbria Railways website that has a pair of units at the station. The cutting can be seen in the background. The upper picture also correlates with this.
I couldn't find any information when or whether modifications took place, but did these units have the second bulb fitment in the light units, like other DMU's, that had both a red bulb and white bulb? This negated carrying a separate tail lamp.
Gloster
4 Sep 2020
Up the creek
I looked through the Driver’s Instructions on the .railcar.co.uk site and there appeared to be nothing about tail-lights, which made me think that fitting a shade might be the guard’s duties, a carefully maintained demarcation. My recollection is that the use of red and white bulbs did not come in until the 1980s.
High Dyke
1 Jan 2013
Yellabelly Country
Fair enough. I couldn't be certain.
Rescars
25 May 2021
Just looked at my 1960 copy of the General Appendix re Working of multiple unit mechanical diesel trains. "An oil tail lamp must be carried on the rearmost vehicle and a spare oil lamp, properly trimmed, must be carried in the Guard's compartment......" So this photo either shows a train about to have a lamp placed, or someone's going to be in trouble, or there really is my hypothetical parcel van stuck somewhere in the previous section!
Gloster
4 Sep 2020
Up the creek
I think that it is possible that the requirement to use a tail-lamp may have been introduced a couple of years after the introduction of DMUs, by 1958 at the latest. If correct, this would date the photo to 1955 to 1958.
Rescars
25 May 2021
Presumably that fits well with the whiskers livery.
John Webb
5 Jun 2010
St Albans
Re the apparent lack of a tail-lamp, could it be that the train is heading for Penrith, possibly on a Sunday and the line being worked as 'One engine in steam' ?
Gloster
4 Sep 2020
Up the creek
Looking at the photos on the .disused-stations site it doesn’t look as though the signalling was set up to allow reversible working. Additionally, there was a level-crossing, so you would have had to have someone in to work that.
John Webb
5 Jun 2010
St Albans
Fair enough!
D1537
11 Jul 2019
Some more - for interest only, it is definitely Bassenthwaite Lake!
lakeland844
4 Dec 2020
Cumbria
Bass Lake - 100% The cutting was just to the eastern end but was swept away when the A66 dualling of the mid 70s utilised the old track bed back to Braithwaite
WesternLancer
12 Apr 2019
View attachment 153143View attachment 153144
V nice to see the pics - the 1st one esp - whilst not technically great (partly out of focus or depth of field problem?) it presents a most enjoyable period view. The Derby Lightweight. the immaculately clipped hedges and shrubbery, period lanterns, smartly painted platform 'furniture' in view etc.
Remarkable to note that on disused stations website pics in c2010 at least show the station buildings in an advanced state of dereliction, but fundamentally still there, after all the years of closure. One would think that demand for housing in the area would be at a premium and thus it might have got brought back into use. I assume there are reasons this did not happen.
WesternLancer
12 Apr 2019
It looks like the station building has been restored; the loco IIRC was made for a film and now resides there:
Thanks for that link - if that is the same building shown derelict on Gallery 4 of this - which it looks as though it is - it's a remarkable and welcome transformation
and I simply failed to notice gallery 5 (!) which indicates the renovation - tho the focus of the pics here are on the ex film stock loco etc being delivered rather than the building so much. Hope the links work
