Oldest piece of permanent way
Unixman
16 Mar 2012
A few days ago I was at Barmouth station heading towards Tywyn when I idly looked at the track below me. Apart from the generally ropey condition of the sleepers, I also noticed that the chairs had BR(W) on them with what possibly could be a date (the numbers were two digit with the first being a "5"). The likelihood then is that the track was laid either in the 1950's or early '60s - so probably at least 50 years old. Which made me wonder: what is the oldest piece of permanent way that is still in regular use by passenger trains (so no sidings, freight only routes etc)?
Ploughman
15 Jan 2010
Near where the 3 ridings meet
The date will only confirm the date of the chairs production.
It can give an inkling of the date of installation in the ground especially if there is a large amount of them together.
The rails should also have dates rolled into them but anything earlier than 1980 gets difficult to read but you need to be right down on the rail to find the marking in general, in fact if in a corrosive area even 2 year old rail can be difficult to read.
In general the oldest rail will be Bullhead. Flat Bottom only really came into general use in the 1950s. Although some was laid by the pregrouping companies such as the LNER in the 40s.
Wood sleepers will be on a continuous replacement anyway so should not get past 50 years or so.
The oldest date I have seen was in passenger lines at Hull Paragon and was from 1913 but it was leading up to the buffers in a platform road.
Elsewhere there was a lot of 1930 ish chairs on the York - Scarborough line.
Hull - Seamer had a high proportion of 1940 and 1941 due to being a wartime divert route and for military traffic for the various airfields and bases down the line.
Trog
30 Oct 2009
In Retirement.
1950's is very common I have also noticed GWR rails still in use in two places on passenger lines, and there is still some LNWR conductor rail in the Euston - Watford DC lines.
route:oxford
1 Nov 2008
It's probably going to be a section of track embedded into a level crossing on the IOW isn't it?
Bill EWS
10 Feb 2006
Didcot
In Michigan I came across a freight line with 1913 stamped on the rail lengths, and that was the main running line and not in a siding. This was back in 1984 and wonder if it may still be in use!
fgwrich
15 Apr 2009
Hampshire
Quite alot of depots & sidings also still retain swathes of original track / chairs - Reading Depot is one, and i think there's a few 'heritage' chairs down in Eastleigh Works still.
Indeed several branch lines will still have very old track on - The reccently renewed Exmouth is one, and you'll probably find some on the (also now undergoing relaying) Barnstaple Branch.
About 7 years ago I pulled out some 1899 Bullhead rail at Cromer during a renewal there. Whether it had been there all that time or not is unknown!
matt
30 Jun 2005
Rugby
Is the date printed on the rail? As some of the rails on the North Warwickshire line have Workington 1960 stamped on to them?
bronzeonion
1 Apr 2009
West London
The chairs leading up the buffer stops at Greenford I think are of GWR design as they only have 1 bolt on each side and the chairs are rounded.
I'll get a photograph of it next time I'm there if I remember!
a good off
2 Jul 2010
Control Room
The Skegness line was always a haven for pre grouping pway with lots of GNR rail and fittings. I'm not sure that this is still the case after the recent relaying work.
Trog
30 Oct 2009
In Retirement.
Examples of rail brandings.
paul1609
28 Jan 2006
K
When the K&ESR entered preservation about 3/4s of the line was in 91 1/4lb bullhead rail that had been relaid from the Elham Valley line during the war.
This had wooden keys and the parts fishplates and bolts were impossible to obtain. As we relaid the line we used the standard 95ib rail and later flat bottom rails.
About 5 years ago we removed the last length of 91 1/4 rail and were very surprised to receive a very generous offer from one of the major track companies for what we have otherwise intended to send for scrap. it appears that they needed the spares for various depots around kent!
The Colonel
1 Feb 2011
The unused platform at Chessington South has panels with 2 bolt fishplates and someone I know said it may well be the original track from the late 30's.
Gareth Marston
26 Jun 2010
Newtown Montgomeryshire
Can't beat "in use" but 10 years ago or so a 158 managed to drop its cam shaft onto the release points at Aberystwyth station and wrecked them they dated from the GWR rebuild in 1926.
TheVicLine
21 Aug 2012
I was on a PWay course recently (LU) and the lecturer said that rail and junction work of 70 years was not that un-common on the network, I thought it was pretty unbelievable but after reading these posts I am amazed.
I think from memory that he said the Met Line around Farringdon was particularly old.
Manchester77
4 Jun 2012
Manchester
There's listed track on the alydwich* branch iirc on the platform shut in 1917.
* can't spell so sorry if I spelt it wrong
DXMachina
24 Oct 2011
I seem to remember an earlier thread on here stating that some track in a station in Hull was dated in the 1870s
