Oyster card during NXEA works
iphone76
6 Nov 2010
South Essex
Evening. Tomorrow there are no trains between Stratford and Liverpool Street on NXEA due to engineering works. Normally, I use my annual season ticket from Wickford to London then use Oyster to get into the west end. (Cost £1.80 single).
Due to the works, I will have to take the Central Line into Liverpool Street from Stratford and then continue into the west end.
If I touch in at Stratford and touch out in zone 1, I will be charged £2.40, rather than the usual £1.80. (Extra £1.20 return). Would I be correct in thinking that my only alternative would be to get off the Central Line at Liverpool Street, go up and exit using my season ticket (it works at Liverpool Street LU) then re-enter by touching in on my Oyster?
I know it is only £1.20 per return journey, but I will be doing this a lot at weekends in the run-up to Christmas and there are quite a few closures at weekends on the line for the rest of the year.
Thank you.
jd
9 Jun 2005
I'd imagine so.
Only thing I could suggest, and it's only any use if you happen to be going in that sort of direction anyway, is to change from the Central line to the Hammersmith & City line at Mile End (which is a cross-platform interchange), then at least when you get to Liverpool Street you're much closer to the ticket barriers so it's not quite as much out of your way?
Edit: Though this depends on the H&C being open, which it quite often isn't at weekends these days...
MikeWh
15 Jun 2010
Crayford
If you want to avoid paying for zone 2 on your oyster then you will have to get off at Liverpool Street and swipe out then touch in. Reverse on the way back too.
iphone76
6 Nov 2010
South Essex
Thanks for the confirmation. Unfortunately there is no H&C line Edgware Road to Barking or District line from Upminster to Embankment!
I think I'll leave a bit earlier, get off at Liverpool Street and catch the bus into the West End.
Cheers.
MikeWh
15 Jun 2010
Crayford
That'll knock it down to £1.20 each way then :)
