O L Leigh
Or is it just 802005 that has big areas of exposed metal around the passenger doors?
Doesn't matter, says Hitachi on the "tin". It's their brand that's besmirchedJust wondering if all the affected units are Pistoia-built and whether we’re seeing another example of the now legendary AnsaldoBreda build quality.
Maybe they were investigating more cracksOr is it just 802005 that has big areas of exposed metal around the passenger doors?
None of the TOCs own their AT300s, they are all leased. And regardless of who owns them, it's still Hitachi's problem - there is normally a paint warranty in new train contracts that is valid for many years.Warranty issues with GW/LNER 800/801s are Hitachi's problem - they are owned by Agility Trains not the TOCs.
802s and other TOC/Rosco-owned AT300s will be different.
Not if its by the doors, the cracking was around the bogies.Maybe they were investigating more cracks
Oh. Wonder if it also affects the Shinkansens Hitachi has made.It’s nothing to do with cracks - it’s just the paint job not lasting. Unfortunately not uncommon with Hitachi, wherever they are built.
IIRC, were the GWR 802s not built by Hitachi's (ex-Ansaldo-Breda) plant in Pistoia, Italy?
All this relating failures to the Pistoia plant's past issues.is irrelevant. It's a Hitachi design, under Hitachi manufacturing control. I doubt that any of the Ansaldi-Breda culture remains there.
I don't believe it is a paint issue - it looks more like metal corrosion under the paint leading to it flaking off. The fact that the vinyl is also bubbling in the same areas on the 800/0s would suggest this.
But the vinyls are stuck to the paint not the metal, so if the paint is coming away from the body it will take the vinyl with it. I would also tentatively suggest that any dulling of the metal is due to exposure to the air as a consequence of the paint coming off rather than being the cause of it. Given that the majority of problems reported so far are around door apertures and coach ends, it seems likely that Hitachi have had problems bonding the paint to the body shells and that it is under some stress due to the curvature at those points causing it to lift.
The Paddington line ran painted HSTs for years with uncleared lineside vegetation brushing the sides of trains, as discussed here previously - look at the Bath fatality, or the Cotswold single line stretches with bushes and trees brushing both sides of the train at once. Yet they didn't get such damage.Or it’s caused by the trains brushing (or hitting at speed) vegetation on the lineside, causing small amounts of damage to the paint, allowing air and water in, which in turn is causing the metal corrosion, and this is causing the larger flaking issues….
In that case should the TOC be claiming from Network rail for the damage?Or it’s caused by the trains brushing (or hitting at speed) vegetation on the lineside, causing small amounts of damage to the paint, allowing air and water in, which in turn is causing the metal corrosion, and this is causing the larger flaking issues….
Aren't 802s aluminium-bodied trains?I don't believe it is a paint issue - it looks more like metal corrosion under the paint leading to it flaking off. The fact that the vinyl is also bubbling in the same areas on the 800/0s would suggest this.
Maybe indicative of where the body flexes slightly, thus cracking the paint that doesn't flex by the same amount?All the sets suffering from this kind of damage all have it in roughly the same position on the door apertures
I am reasonably well versed in what happens to paint finishes on vehicles. If there's an issue with paint adhering to the bodyside it will usually chip or flake off. It appears to be bubbling on the 80x fleet which is why I'm sure it's corrosion related as it indicates a chemical reaction of some sort.
Aluminium and steel don't mix well - you get a chemical reaction called galvanic corrosion where the electrons in the aluminium transfer to the neighbouring steel and the aluminium becomes more susceptible to corrosion.
If you look at where the paintwork tends to bubble on other rolling stock, it's where aluminium and steel are in close proximity; HSTs have aluminium window frames next to steel bodywork and they corrode. 158s have aluminium bodyshells and the bubbling on those occurs next to steel fittings - window vents, frames and yaw dampers for example.
It also occurs on vehicles (buses as well) well aluminium panels are in close proximity to steel framework.
I will reserve judgement, but I tend to agree with you.I don't think repairing the paintwork will resolve the root cause of the problem here.
The length of the vehicles doesn't make any difference, - they are cleared for the routes that they use.I suspect it’s caused by striking lineside vegetation. All the sets suffering from this kind of damage all have it in roughly the same position on the door apertures, maybe not helped by length of the vehicles?
