Which is *meant* to be going to Lincoln, but isn't because of rolling stock availability AIUI.
What do you mean "is meant to be going to Lincoln BUT ISN`T" ???
I thought it was a franchise commitment and as a resident of Lincoln we haven`t been told this. Where do you get this information from? Aren`t the IEP bi modes for such routes ?
Sorry - should have been clearer - isn't because it's currently operated by a 91 & Mk4 set which struggles to get to Lincoln shortly after leaving Newark......
Correct, replacement of the 91 & Mk4 with bi-modes or an HST would address this.
"A key feature causing capacity constraints and affecting performance on this SRS is the mix and sheer volume of traffic between London and Bedford and in particular the problems of platform capacity at St Pancras International and Bedford. St Pancras International has four platforms in the high level part of the station for all East Midlands train services. The limited number of platforms is a capacity constraint, against the background of strong growth in demand for these services in recent years."
https://webcache.googleusercontent....e%20Specifications%202011%20East%20Mids.pdf#5
...or the actual PDF if you prefer:
https://www.networkrail.co.uk/uploa...Plans/Route Specifications 2011 East Mids.pdf
Perhaps relevant is the next paragraph
"Another major capacity constraint for this SRS is the Bedford station area. The station has five platform
faces in total, but all terminating/starting First Capital Connect services and southbound East Midlands
Trains calling at Bedford must use just three platforms and, together with freight services, they all use
the slow lines between the station and Bedford South Junction. This limits the number of southbound
East Midlands train services that can call and causes congestion during perturbed operations. "
Which I think is the point Bald Rick was making - which is 4 platforms are easily sufficient for 8 tph departures (as an aside Moorgate manages 12 departures an hour out of two platforms in the peaks) - however the problem you've got is the line from Kentish Town northwards is congested with the high volume of Thameslink services - and indeed as the bit of the document I've just added shows, currently Bedford station is also a blocker in terms of providing more services arriving from north of there.
