gimmea50anyday
With the advent of Thameslink 2000 and the platform extensions at Farringdon blocking access to the Moorgate branch this route was subsequently closed. Obviously no mainline services have served the stations at Barbican and Moorgate since then and although the track remains in situ the OHLE and signalling has gone and the tunnel mouths have been cordoned off.
On a trip to London recently I was on the circle line heading towards Kings Cross and as the train approached Farringdon I noticed in the space once occupied by the trackbed there was a new set of pointwork under construction with one of the trailing routes clearly pointing towards the barbican/moorgate tunnels. I couldnt see any other location nearby where the pointwork could be used once constructed so is this indication that the branch is to be recomissioned as part of the SSL Met/H&C lines?
