Porterbrook Cl.769 'Flex' trains from 319s, initially for Northern
py_megapixel
5 Nov 2018
Northern England
Er NO. Cue - lots of objections from Cumbria!!
Not necessarily valid objections though.
Those trains have to run a huge distance under the wires, and then through the notoriously congested Castlefield corridor (every extra train through there is an operational liability, on the pre-covid timetable). I wouldn't have thought any funding is forthcoming for electrification of the Windermere or Barrow lines. Plus those branches are self-contained, so timing them for neat connections should be easy.
In a time when the railway is more squeezed for funds than ever, I can't really see how one could justify keeping the oddball through services, particularly from Windermere.
D9006
28 Aug 2019
Wigan
Good start today, 6 rostered out. 431/4/48/50/58 on Alderley Edge diagrams and 456 on a stalybridge diagram
nightflyian
12 Oct 2021
Southport
448 and 456 arrived at Southport as a 8 car service okay. 448 uncoupled from the rear unit and front unit now won't move ! 0730 is the 456 unit of the rear. 2 train crews trying to work out the issue. Hard shutdown not fixed the issue issue either !
Suspect a door fault.
458 has just pulled in from MCV and is now going back out as the 0730 Southport Stalybridge service running express to Wigan. The other 2 units still stuck at Southport with suggestions the rear unit 456 will be the 0815 SOP-ALD service.
nightflyian
12 Oct 2021
Southport
I see 434 has failed this morning at ALD then taken of service MOX and appears to be currently sat in the Turnback sidings at MCV !
Jamesrob637
12 Aug 2016
The 16:16 Southport to Alderley Edge seems to be booked 769 once again which is a good thing given the time it passes through Manchester.
wrinkley
6 Feb 2015
While looking for progress on the Lostock - Wigan line electrification today, we had four sightings of 769s. I also saw three around Lostock yesterday, I am starting to think that things are improving.
AMD
6 Dec 2017
So todays failures were 448 at Bolton (albeit it managed to get to Wigan eventually) and 450 which had a problem after Burscough Bridge this morning.
D9006
28 Aug 2019
Wigan
Another good start to day allocation wise, all 5 diagrams on Southport to Alderley Edge and the 1 diagram on Southport to Stalybridge showing booked 769s, noticed 0550 starter from North Western has been 2 car 150 till today
Geeves
6 Jan 2009
Rochdale
Don't speak too soon as 448 is having issues straight off the bat on the 2L70 0637 Vic - Southport
AM9
13 May 2014
St Albans
448 managed the 08:15 Southport yo Alderley Edge OK. Maybe it's earlier delays were caused by other services.
Geeves
6 Jan 2009
Rochdale
Some mind of pantograph issue out of the turn back this morning. Glad it went right in the end, there was another half an hour down around the same area, not sure if they all made it all day.
Killingworth
30 May 2018
Sheffield
AM9
13 May 2014
St Albans
Well a pantograph issue is likely more of a donor 319 problem than the new diesel gensets.
507020
23 May 2021
Southport
And if you’ve got a pantograph/AC issue and you’re on a Victoria service you can always just try running on Diesel/DC mode if that avoids cancelling it
AMD
6 Dec 2017
424 services cancelled between Wigan and Southport, arrived Wigan on time and resumed its booked working on time
424 had a bit of the bodywork on the front cab hanging off, that was the reason for it's cancellation to Southport at 9pm last night.
507020
23 May 2021
Southport
I saw 424 arrive on time to Southport at 9pm last night and can confirm that it wasn’t cancelled.
D9006
28 Aug 2019
Wigan
All 6 diagrams up to now have run fault free today, running much better now, only problem was a person being hit by train, so a Wigan - Southport- Wigan was missed. Is it too early to say units might just be settling down now
AM9
13 May 2014
St Albans
Some must think that a constant stream of reports that blame every delay on the 769s' performance will give them a bad enough reputation that they will be replaced years before planned. They must be disappointed when they don't go wrong giving them nothing to complain about.
