Peter Sarf
Usually called a "shore supply" and connected to the coaching stock. I believe such a solution had been added to the depot at Scarborough.As a genuine don’t know question - have there ever been any instances where diesel stock such as the 68 had some form of electrical connection to be fitted (ideally automatic, such as some locating connection which connects / disconnects at zero speed under the loco - with the purpose of providing shore supply for the train services in platform, allowing the engines to run up and take over in the moments before departure ?
Ignoring the noise for a moment, it seems strange that this hasn’t been pursued (doubtless in some simpler and more obvious way than I have pondered above) from an environmental perspective aside from anything else, particularly in the diesel heavy terminus train sheds.
I can see it not being popular for shorter stops even at Marylebone. It is a faff to connect and dis-connect that would be tricky on shorter turnarounds.
Something slicker like a fast charge connection might be better. So some conductors that were energised only when an appropriate train was over them and contact made by shoes being lowered or conductor raise. Along the lines of the fast charge connection about to be trialled at West Ealing.
