That is the plan!Does that mean the 221 EPS differentials will be retired on that section from the same date?
Can they run at MU speeds?
At the moment yes, but they are having a large fleet upgrade and plans have been mentioned for five coach trains, splitting for Aberystwyth and Cambrian Coast along the way. Could be this year.
Appreciate I’m a bit late replying here, but last I saw TFW’s Birmingham plan was virtually all 4 cars, I think a 2 car for the departures from Shrewsbury at 5:18am and the 21:30,22:30 and 23:18 (only to Wolverhampton). With the 7:30 and 15:30 departures and their return working from Shrewsbury being 6 cars.None of these things will be true as the 197 rollout takes place (other than that some will be 2-car if only going to/from Aberystwyth, but they're much better at taking standees than 158s).
it will also be 90 PS 100 MU and 125 EPS at Linslade on the DF
Agreed!When I saw that on the plan I raised my eyebrows. A lot. All I can say is hold tight!
Vehicle change to reinstate 390 MU classification was completed November 2021!Yes and yes.
EPS - Enhanced Permissible Speeds. Put simply, these are the 'tilt' speeds 390s and 221s can use on the WCML. In some places a lower figure applies to the 221s vs 390s as the Super Voyagers have a lesser degree of tilting (6 degrees against 8).
MU - Multiple Unit. A differential speed certain classes of multiple unit can use. 22x are included. 390s were not but apparently will be added.
PS - Permissible Speed. The ordinary speed limit useable by all trains up to their speed ceiling.
Reinstate? Interesting.Vehicle change to reinstate 390 MU classification was completed November 2021!
I assume it was to benefit the drivers and not have so many different signs, with the risk of an irregularity, plus such a small section of MU locations on WCML, which will now have the whole route as far as Weaver available so makes sense. In theory the PS will only apply to 390s now where there is no MU speed when not tilting.Reinstate? Interesting.
When and why did they ever lose it?
Tilt failures seem to occur far less regularly nowadays.In theory the PS will only apply to 390s now where there is no MU speed when not tilting.
In the early days of Class 390 introduction there were a couple of sections of route with MU 125mph speed limits where the OLE could only support 110mph (between Rugby and Coventry and Wolverhampton and Stafford). This had not been an issue previously as the electric locos had a maximum speed of 110mph. I think the MU classification was removed as a convenient method of limiting Class 390s to 110mph in these areas.Reinstate? Interesting.
Restricted to 750bhp in normal operation, but they are otherwise the updated, more powerful version the EMR 810s have - of 985bhp.Are the new Class 805 engines set at the lower 750hp setting as per original 80x spec as used by LNER or the higher 940hp setting as GWR use?
And had anyone worked out revised SRTs for North Wales based on slower acceleration compared to Class 221?
And what is the time deficit on the 80x SRT's going to be from Crewe to Holyhead for an 80x compared to a 221?Yes.
Surely you mean compared to a 221?And what is the time deficit on the 80x SRT's going to be from Crewe to Holyhead for an 80x compared to a 390?
Does anyone know how the traction system on 805's 807's is going to allow stronger acceleration compared to Class 801 on electric when they share the same traction motors taking into account that current performance suggests the 801's are running at full power anyway based on the tractive effort and power curves?
For what it is worth my best Pendolino run from a standing start to three miles is only 20 seconds slower than a Class 801 over the same distance. The difference is not that great unless you run a stopping at all stations service.
The bigger difference is Class 801 vs a HST which would be 90 seconds behind an 801 at 3 miles and 2 minutes behind after 8 miles!!
Whoops yes Edited lol. brain thinking faster than fingers.Surely you mean compared to a 221?
If RTT is accurate, they are already using 80x timings it seems.Whoops yes Edited lol. brain thinking faster than fingers.
Yep, they're using the DMU805 timing load already (shown on RTT as a Diesel Locomotive at 125mph, rather than 220/221). The timing load changes slightly from June to run with the EMU800 timing load from Crewe to Euston.If RTT is accurate, they are already using 80x timings it seems.
Thank you.Yes and yes.
So a net three min slower for 805 sectional running times Crewe to Holyhead compared to 220/221? Seems about right. Let's hope the 805's are more reliable than GWR 80x on diesel, because they are very slow with an engine out. Voyagers are fine with 4 of 5 engines runningLooking at 1D83 (was in the VHF timetable 0910 Euston-Holyhead, is now the 0902):
Currently, presumably on 805 timings, it is given 2h02m Crewe-Holyhead.
Pre-Covid in 2019, as a double Voyager, it was given 2h07m.
From June the timing (from RTT) is 2h05m.
However, the 2019 times have 1 minute for the Chester stop, while the current and future schedules have an 8-minute stop, maybe allowing for unit division.
Timings west of Crewe are not exactly demanding.
This is due to an additional Flint call on this service from June. All Avanti passenger services are currently running using 805 SRTs on the NWC.So a net three min slower for 805 sectional running times Crewe to Holyhead compared to 220/221? Seems about right.
My thoughts exactly, I don’t fancy being the first through linslade tunnel.When I saw that on the plan I raised my eyebrows. A lot. All I can say is hold tight!
Is this in writing anywhere? 390’s are still shown as excluded from MU speeds.Agreed!
It is only the EPS differential preventing it being rolled out before now (to my knowledge - AWC may have briefed drivers etc but I doubt that due to the very small benefit that would have before the MU speed profile goes live).
Cheers. This is interesting. I’m sure Avanti will get round to briefing us eventually.
So does anyone know what the net difference in SRT's are between the previous 221 timings and 80x diesel?This is due to an additional Flint call on this service from June. All Avanti passenger services are currently running using 805 SRTs on the NWC.
The 0910 as it was use to be a 10 car throughout but now seems to just be a 5 car. Looking at Chester for the new timetable the does seem to be a 1132 to London from platform 3 as well so it does seem there will one day be a split on this service as the 1132 is currently a 'runs as required path'. Later in the day it seems that both units will then join again with the 1606 from London joining with the 1632 to London from Holyhead.Looking at 1D83 (was in the VHF timetable 0910 Euston-Holyhead, is now the 0902):
