Progress on Avanti West Coast's 805/807s Hitachi AT300 sets
hexagon789
2 Sep 2016
But limited to 110mph?
On the one occasion I used a Voyager with tilt disabled that was the case.
Nothing runs on the WCML above 110mph without operational TASS, I think.
Because only the EPS limits extend above 110mph currently, except the 90/MU 125/EPS 125 bit on the Birmingham loop.
The in place but bagged MU signs on Euston - Weaver are intended for the 80x to use, increasing the ability of non-tilt trains (but only those passed for MU speeds) to run at up to 125mph in places; mostly 115/120 in practice.
Skie
22 Dec 2008
The ORR aren't that twitchy, otherwise the 390's and 221's would require speed supervision when running non-tilt due to a TASS or tilt failure. At that point my understanding from an experienced ex VT and Avanti driver is that TASS is usually isolated - which allows the train to be driven without SS monitoring and/or intervention.
But lower maximum speeds apply when TASS is isolated and drivers are expected to know that already. The issue is 2 new classes of train that are expected to use a newly implemented speed profile that will be introduced in phases. It really is a recipe for mistakes to be made.
If you’re introducing a new train on a line fitted with a safety system, it does seem odd to not also fit that system. We don’t know exactly what they’ve asked Avanti to implement, could be they want TASS to control speeds down to a lower range than it currently does on the 390s.
Boodiggy
8 Nov 2012
Am i right in thinking the tilt is only for passenger comfort, it's not like a 805 will topple over at the 390 speed
Lowest roll over speed for the 805/7 is 134mph at Atherstone.
Its why the 90mph TSR is on the Down TV Fast.
TILT is isolated.
Not TASS.
Another risk is it is a new Speed Profile with plenty of changes. Many more than the current PS or EPS.
InTheEastMids
31 Jan 2016
I'm still confused about how we've got to the point that the trains are now in service, but this hasn't been resolved.
We are nearly 5 years on from the appointment of Hitachi as a supplier
800001
24 Oct 2015
Hitachi will of built what they were specified to, the blame to me lays with the Avanti procurement team!
poffle
11 Oct 2023
Dublin, Ireland
Not if the regulator gave no indication of a requirement for an additional safety system at the design stage .
I'm pretty sure if the regulator had said they wanted a new speed control system on the new microfleets that would have killed the new train project.
If Avanti wanted additional capacity they would then have looked to get class 221s from XC and refurbish them with TASS. Probably also discontinuing through trains from Euston to Noth Wales.l
Then XC would have been in the market for the 805 type train.
There is a strong feel here of communication breakdowns within ORR.
Railperf
30 Oct 2017
Until now, TASS was only required for tilting trains wanting to run at EPS limits. None of the other trains using WCML fast lines have any form of TASS or SS fitted. That includes Class 195, 331, 350, 730, New Measurement Train, Class 802, Class 397.
And we have to remember the proposed new MU limit is still not approved yet with signs bagged over until further notice.
Peter Sarf
Croydon
I can see where your coming from until I remember all will have been blinded by the desire to reduce diesel operation under the wires !.
Any further discussion along these lines deserves a thread of its own.
43055
8 Mar 2018
Had a short trip on 805001 earlier and certainly thought the interiors were better than the GWR and LNER examples that I have travelled on. My only criticism would be the number of announcements before we set off. Must of had about 4 or 5.
Statto
8 Feb 2011
At home or at the pub
Caught an 805 Chester to Bangor couple of weeks ago, whilst i found the seats comfortable, i felt the automated announcements are far too loud & intrusive, & sheer number of them is really annoying too, there is such a thing as noise pollution.
Harpo
21 Aug 2024
Newport
Quite. Who polices the policeman?
I suspect the ORR position is that of not accepting any increases to safety risk, and moving from automatic system to mk1 human does that. (Just consider the reverse of it.)
There would presumably be no ORR issue in operating the same trains on any other line without an overlaid supervisory system?
irish_rail
30 Oct 2013
Plymouth
I'd agree. Only had the one trip but the announcements where set way too loud. Also the high backed seating made the coach feel very crampt compared with the GWR 80x I'm more accustomed too.
Roast Veg
28 Oct 2016
If I remember correctly, TASS already uses eurobalises. Could a software modification to the 805s and 807s allow them to use the existing speed supervision using their existing ETCS equipment?
Pendomonium
24 Aug 2024
Tring
Tilt & speed supervision is mainly for passenger comfort. However. the class 390 & 221 were designed to tilt with calculated tip points & a suitable wheel profile. It has been mentioned that when TASS fails, the 390 or 221 does not fly off the track. This may be true in an instant, but failure of TASS initiates an emergency brake application to bring the speed of the train down to below that of the PS speed at that location. Running with TASS isolated or temporarily defective will result in horrendous ride quality approaching EPS speeds. The question about 80x tipping over on the WCML is answered with a yes. TASS strictly monitors the speed profile to which the driver must conform, including the braking curves. On the WCML the abundance of EPS running at 125 MPH means that there are a few key locations where a drastic speed change is observed, other than at junctions. Thus a class 390 with TASS can happily charge along the WCML at 125 MPH for long stretches. In broad brush stroke terms TASS will " allow" just a 2-3 MPH overspeed before it expresses to the driver its displeasure. If the braking curve is in danger of not being met, an emergency brake application will occur. The class 80x has had to be shoe horned into this method of operation with the MU speed profiles offered as a "fix" to fit in the EPS timings. However, as has been highlighted the WCML 80x series has no speed supervision system. It has no DAS system either. All it does have is a speed limiter on the train Management system, which is set like a cruise control. A whole breed of 390 driver has been taught to accelerate carefully & brake carefully only to be now told that the new trains are to be accelerated hard & have superior brakes. The number of speed increases & decreases with trying to introduce MU speeds is greater since there is a stepped up & down approach. Now back to the tipping over... It would appear that once the MU speed profiles were set & £16m spent on putting the boards up, it became clear that there were indeed locations where a class 80x mistakenly operating at EPS plus the 2 - 3 mph would catastrophically derail owing to its different length/weight/wheel profile/etc. At the very least the risk of significant injuries to persons on board is high during predicted overspeed events. Thus we are now in the situation where the mitigation of such risk is to limit the Avanti 80x fleets to 110MPH & monitor the speed adherence of every single one to build up a bigger picture of the risk. It has been mentioned why not fit the WCML 80x fleet with a TASS? Its all down to money. Balises for 805 APCO have not even been installed. Engine pre heat is done either manually or via GPS fix, which is not always functional (to which the number of door release issues testifies). Whilst the current 805 / 807 fleet monitoring is taking place it is hard to say what the eventual decisions will be. What I can say is that the current 805/807 monitoring is producing some data of concern.
Avanti have been asked to implement a review of every 805/807 journey in relation to speed profile adherence. This data is then likely to be used to determine a way forward, or backward, as appropriate. I would think that until absolute adherence to the currently imposed restrictions is presented to ORR then the MU boards will remain covered up.
A lot depends on money. 807s were not ordered with a donkey engine to save money. 807s & 805s have no functioning Driver Advisory System. Re writing the software is going to cost. GPS rather than balises is used for engine pre heat & door release information to save money. Since the 805/807 has no in cab signaling, everything relies on a driver adhering to new extensive speed step up & step down profiles without the back up guidance of speed supervision with some areas presenting a significant tip over risk should it all go wrong.
There is a (non tilting) train of thought that Avanti backed themselves into a bit of a corner when they waxed lyrical at the select committee meetings about how they were about to recruit loads of new drivers & introduce new trains only to be asked, when? The whole introduction appears to have been a scramble with fragile training plans & lack of forethought regarding how the MU speed profile will work in practice. The fact that major questions only started to get asked at this stage suggests that there was a gap between collective decisions & responsibilities. Thats one opinion anyway.
Boodiggy
8 Nov 2012
The amount of changes in the MU speeds between Kilburn - Rugby / Nuneaton is ridiculous.
Slightly changed from the original plan too, with EPS differential now remaining.
North of Nuneaton to Weaver the changes are not as drastic although still a few short sections of MU.
Pendomonium
24 Aug 2024
Tring
The section North of Nuneaton does include some of the areas declared particularly at risk of overspeed incidents where the driver has to be absolutely spot on with the step down speeds. Although a 100MPH restriction remains in force due to structure resonance issues between Lichfield TV & Rugely TV.
andyjhatton
8 Apr 2023
Dartford
Can't say I understand the obsessive focus on this specific situation.
Maybe the ECML speed profile should be immediately downgraded after the LUMO incident.
Maybe we should instantly roll out ERTMS Level 2/3 to all intercity routes (oh no, there's no money for that)
steeevooo
18 Jun 2020
I think I've previously heard that the original MU profile was designed in conjunction with some Avanti Driver Managers - presumably they would have agreed that the profile was manageable and "driveable" by the Avanti drivers given all considerations? It really does seem a pickle and I hope there are lessons taken away from this by all sides.
Avanti's order with Hitachi for non-tilt 80x was actually made just prior to them taking over from Virgin in December 2019.
They won the the franchise in August 2019, so it doesn't sound as though there was much time for technical consultation before the order was placed.
Network Rail would have been involved in the preparation of any plan for higher non-tilt speeds on the WCML.
From what we can tell Avanti paid NR for work on delivering the MU speed profile, so it must have their full support.
The debate is reminiscent of ORR's objection to a proposal by NWT to use (I think) class 309s on a Crewe-Carlisle stopping service.
309s had slam doors, and the route had just eliminated them on inter-city stock, so ORR objected to a route regressing to slam door operation.
We are still waiting for a Crewe-Carlisle stopping service, even with a surplus of compliant EMUs.
Did that include reopening Coppul, Garstang, Shap, Wreay etc ? :s
Not as far as I know.
The aim was to link existing stations hourly, taking some stops out of long distance services.
Among other things, it would have connected Winsford/Hartford to Warrington and further north (via Newton le Willows I think).
The only extra services since then have been Liverpool-Preston-Blackpool, connecting Balshaw Lane and Leyland.
Meanwhile the 4/5-stop long distance services have been baked into the timetable, which used to have several with only Preston stops between Crewe and Carlisle.
There was an NR plan for an extra Euston-Preston (-Lancaster/Blackpool) which would have taken Warrington/Wigan/Lancaster stops out of Glasgow trains, but that never found its way into a franchise spec.
Boodiggy
8 Nov 2012
Indeed.
A no end in sight for the TSR at Atherstone. All delay going to AWC.
Railperf
30 Oct 2017
And seemingly without any performance problems at 110mph (on time or early throughout) .
The semi-fast runs via Birmingham are not taxing even at 110mph. I note the only section where it lost time was Rugby to Milton Keynes - appx 2 min - but the long booked stop at MKC meant it departed on time. As with IEt introduction on GWR, the 805's make the most of engineering allowances and dwell times to have a chance of staying on time where a Pendolino driven on the same schedule to the linespeed profile could start to run early. Then it depends on driving style as to whether the driver starts to take it easy or whether he is happy to arrive early - dpending on the proximity of services ahead. Seasoned drivers start to learn where they will catch up earlier services and might start to ease off to avoid caution signals. It also depends on TOC Policy. I'm told that one open access operator is happy for its drivers to stay at line speed following the signals. The train of thought being that if another service ahead is running late, there will be greater opportunity to pass it than hanging back.
sh24
28 Sep 2023
I'm on the 1H25 right now, which was 7 late from Euston so went out behind the 9G26, formed of a pair of 805's. We were checked when they stopped at Watford (fair) but it was noticeable how the Pendo would caught up with them 4 times between Watford and MKC, with brake applications, reduction in line speed and the consequent loss of 4 mins too. We were certainly driving to the signals.
Thankfully the 805's were put inside at MKC and we are now off and away, albeit only 30 seconds from a delay repay. Not going to make running the WCML any easier...
Railperf
30 Oct 2017
LAst time I travelled on 9G26, 1H25 was stuck behind it all the way to Rugby, by which time it was well into delay repay territory. I did wonder why it wasn't let past at Milton Keynes - the first genuine passing point - possibly signaller too busy to do anything about it. In this case the slowing down for station stops and dwell time loses more time than 110mph vs 125mph running. if a Pendolino had been used for 9G26, it might only have been a few minutes quicker to Milton Keynes. Any idea why 1H25 was late departing Euston?
