What are they going to do to the 319s then, if you say the 317s aren't up to it. Aren't they almost identical, give or take a couple of years?
Not even London Underground so it would seem!I think you mean more than one 'A'.Very few people know that Stansted does not have an 'A' in its spelling.
I have no idea what this proposed "radical refit" that you refer to will involve or how much more life this will give the Cl319's. My suspicion is that it won't actually be anywhere near as radical as perhaps you are hoping.
O L Leigh
The 319s were 1987-1888 and the later ones in 1990, which gives a nine year period in which the 317s and 319s were built.
Wow, that is amazing in we can build trains and go back in time at the same time!
I think I read somewhere that the continuously glazed windows that the 170s have aren't safe as in a crash they are more likely to smash?
Major mechanical overhaul...
...complete gutting and rebuild inside...
...air conditioning added, disabled toilets (unless they get rid of them?).
I would say a pretty major job.
Not a biggy. Probably a similar installation to the Cl317/7's, together with the associated lowering of the ceiling panels to accommodate the ducting. Unfortunately the disabled loo will mean the loss of quite a lot of seating.
They.. ..will use Bombardier's Orbita predictive monitoring system to report faults back to the depot.
Wow, that's probably the most important bit of the train. Given their amazing track (sic) record of building new trains, the depot better have a stable, high-bandwidth, data connection!
System: Whole train's fubared. Solution - get a 380 in to do the job properly as Derby still can't build trains.
Bombardier has two production lines running, and expects to deliver the EMUs between March and June next year.
Not an issue at all in the NW - they will be replacing 2 car trains and also operating at a greater frequency.
Not a biggy. Probably a similar installation to the Cl317/7's, together with the associated lowering of the ceiling panels to accommodate the ducting. Unfortunately the disabled loo will mean the loss of quite a lot of seating.O L Leigh
