Rail Charter Services to operate loco hauled trains between Skipton & Appleby.
DB
Guest
18 Nov 2009
Because 90s have buckeyes, 47s don't perhaps and I think the outer end of the TSOE is buckeye only, not a drophead
Most of the 90s don't have buckeyes fitted any more, as I recall (think it was only the GA ones which still had them). As regards Mk4 sets, there are standard buffers and coupling hooks on the outer ends of the set - i.e. the TSOE loco end and the DVT nose end. Internally, they use fixed-head buckeyes (so if internal vehicles from the set are moved on their own, barriers are needed as with HST trailers). So for a set which could be coupled to non-buckeye locos at both ends, it would need either a TSOE or DVT at each end. A DVT would be dead space, but without it there would be no brake vehicle or guard's accommodation. The physical wiring between vehicles on Mk4s and earlier coaches is different, so it wouldn't be possible to mix and match - e.g. mk4s with a mk2 brake. Not sure how the door control circuits work either - i.e. whether they would work without a DVT.
But perhaps more to the point, LSL owns the mk3s as part of their charter fleet. They are hardly going to rent something else! I'm also not sure whether mk4s are cleared north of Skipton.
Not entirely sure what the PRM rules are for charter fleets, but I'm sure they are less restrictive as these are not ordinary public service trains. Clearly slam doors are fine, given that all charter operators have only slam door stock, and LSL are expanding their fleet at the moment (mk3s, HST).
Incidentally, anyone seen any mention of whether they are going to be insisting on masks, like service trains? I'm local to the area so might well have a trip out, but if masks are insisted on then forget it!
10 Apr 2020
Most of the 90s don't have buckeyes fitted any more, as I recall (think it was only the GA ones which still had them). As regards Mk4 sets, there are standard buffers and coupling hooks on the outer ends of the set - i.e. the TSOE loco end and the DVT nose end. Internally, they use fixed-head buckeyes (so if internal vehicles from the set are moved on their own, barriers are needed as with HST trailers). So for a set which could be coupled to non-buckeye locos at both ends, it would need either a TSOE or DVT at each end. A DVT would be dead space, but without it there would be no brake vehicle or guard's accommodation. The physical wiring between vehicles on Mk4s and earlier coaches is different, so it wouldn't be possible to mix and match - e.g. mk4s with a mk3 brake. Not sure how the door control circuits work either - i.e. whether they would work without a DVT.
I cannot really see how masks would not apply.
As long as you've got one of the below combinations:
  • A TSOE on both ends
  • A DVT on both ends
  • A TSOE and DVT at either end
Then a Mk4 is just another carriage in the same way as Mk1s to Mk3s were and are.
DB
Guest
18 Nov 2009
Mk4s have not got the same level of route clearance though.
Not sure of the practicality of a TSOE both ends - i.e. no brake or guard's acommodation.
43096
23 Nov 2015
DB Cargo 90s don't have buckeyes. TOE is therefore drop head buckeye.
hexagon789
2 Sep 2016
Wasn't aware of that about 90s other than the original Freightliner batch.
Masks could put a lot of people off I think but it may well be required
43096
23 Nov 2015
Not quite - Mark 4 sets have Tightlock couplers internally in the set, not fixed buckeyes. "Fixed buckeyes" are essentially what an Alliance coupler is (as used on the HST fleet) and Alliance couplers and a buckeye will happily couple together. Mark 4 sets have standard buffers and drawhooks on the DVT and drop-head buckeyes and retractable buffers on the TOE outer end. Normally they run with buffers retracted and buckeyes in use, to couple to a Class 91.
As for the Class 90s with drop-head buckeyes, once Freightliner have finished modifying 90003-015, it will be just 90001/2 left with buckeyes.
xotGD
4 Feb 2017
A very interesting development, but if they want to maximise patronage then having something other than a 47 on one end would be advantageous.
Depends on the market - if they want to attract 'normal' passengers and put off enthusiasts a 47 is the correct traction. This is not a train for 'cranks'.
Ianno87
3 May 2015
Hmmm. Would seem to imply end of "essential travel only" on or before July 12th then....
DB
Guest
18 Nov 2009
Not really. A kettle is a much bigger draw if wanting to attract the general public. Also a lot more expensive to operate, of course, and I'm not sure where the nearest servicing facilities are - probably Carnforth although there might be some basic facilites at Hellifield.
43 302
25 Oct 2019
You can travel now non-essentially, although most TOCs don't seem to admit it yet. Check the government website. Only GWR I have seen on twitter say you can travel for leisure but to make sure you socially distance and wear a mask etc.
Ianno87
3 May 2015
I know. But it would be indefensible for any TOC to continue to claim this with these trains running. Would suggest there would be a full dropping of this message by that point (hopefully!)
Right, so a group of 47s and some coaches that can be parked up at Appleby is a good compromise.
Swimbar
31 Jan 2018
Wetherby
Certainly Tornado drew the passengers when Northern tried it - Keighley WVR probably the nearest servicing facilities
CW2
7 May 2020
Crewe
Sorry, I read as far as "Class 47" and my eyes glazed over.
Nice idea for normals, but won't appeal much to the enthusiast market - apart from that weird sub-group of Duff bashers.
37424
10 Apr 2020
From what I gather elsewhere they don't want enthusiasts hence the dull traction although I doubt it will totally devoid of enthusiasts.
xotGD
4 Feb 2017
They've got two potential markets. Day trippers and cranks. It would seem odd not to make the appeal as broad as possible by dropping a 37 on one end.
WCRC tap in to both markets on the Scarborough Spa Express. It's good business.
hexagon789
2 Sep 2016
Better window spacing I would think.
Well only in the sense that the seating bays all line up with the windows, but one could always reseat a Mk3 to give 64 seats in a 2+2 configuration with an all table bays arrangement like that of a Mk2 standard open
37424
10 Apr 2020
Well you could but in the current social distance setting where they are only selling window seats not really much point. just use the 1st class carriages
