PmslMerseyrail
507
508
or maybe
508
507
I can't decide!
PmslMerseyrail
507
508
or maybe
508
507
I can't decide!
This type of ranking always ends up biased towards traditional long distance stock, which would be totally unsuitable for shorter distance routes
On South Western for example I'd much rather travel on a 444 than on a 450, never mind high density stock like the 455 or 707, but the 444 would be a disaster on the stopping services out of Waterloo.
Ditto the Chiltern Mk3s, where the tiny end doors would increase dwell time enormously when compared to the 168s and Turbos
What about the 170's ? Obviously I prefer a 3-car one turning up instead of a 2-car as seat reservations in Coach A or C is easier to get to.Crosscountry equally easy!
HST
221
220
(221s above 220s because the heavier bogies make them ride slightly better, and most of them are 5-car so slightly less overcrowding under normal circumstances).
In my opinion (and I'm one of the Mk3-MU haters, I'm sorry to say), they are:Not ridden enough of other TOCs but why all the hate for the Mk3 based multiple units? Networker turbos are far worse and bar the GA Stadler units all of the new trains I've ridden have had the worst seats!
Agreed. Faraday cage glass a pain.More often than not, especially early morning (e.g. 0712 from WEL to LEI) the 4 cars of standard (pre COVID) would fill up much quicker than the 3 cars of 1st. HSTs had 5 standard cars and 3 first cars. In my opinion, Coach F should have half of its 1st removed in a 222.
I might have rated the 222s higher if the following were fixed:
1) Metallic windows in carriages. Yes, the windows of 222s have metal film/RF screening, making phone signals nonexistent and putting excessive pressure on the WiFi. The 43s and Mk3s do not have this problem, I don't use the WiFi on a Mk3 because I can get up to 70Mbps on 4G. The latter is impossible on a 222 due to the RF screening, and 0.1Mbps WiFi is completely useless.
2) Interior revamp, the interiors on the 222s aren't looking their best, with rips/tears/wear on the seats and windows that are filling up with condensation. At least the seats are 2+2 though.
3) interior lighting. Small lamps in the overhead luggage racks that have different color temperatures as the bulbs are replaced. Harsh looking light (possibly CFL?). Inefficient halogen lamps above the central walkway. The fluorescent tubes and LED lamps (in the vestibule ends) in the Blue EMT Mk3s are much better.
As things stand, the 43s and Mk3s are much better than a 222 due to the above points (especially the Faraday Cage Windows).
You do get the comfortable seating at the end of each coach in these units. Most of the time though they are already taken as, as you say, no one wants to sit on the ironing boards!377120 - 377139. So unpopular, that many commuters seem to know the numbers and actively avoid them, even on the really busy services. You see them legging it up the platform if the lead unit is one of these horrors. 3x2 seating throughout.
I have to ask, as it's been some time since I travelled on Southern, what interior do 377120-139 have these days?On my patch (Southern), I would rate the trains as follows.
171
First batch 377/1 (377101 - 377119 only). 2x2 seating throughout.
377/3 also 2x2 throughout (except I guess 377342, which is reduced 377/4, so would have 3x2 in the centre carriage)
377140 onwards, 377/2 and 377/4 end carriages (but not over the bogies as the ride can be very tough)
377/6, 377/7 and likely 387/2 (not travelled on the latter, but they have the same seating as the others in this group). Ironing board seats.
313 do the job they were brought in to do.
455 a bit noisy and tatty now, but not bad trains.
3x2 ironing board seats throughout, with the exception of the inner ends of the driving trailers and first class. There are also some 2x2 ironing boards at the end of one of the intermediates.
1) I've noticed that on some of the well used EMR 222 tables/chairs. Wondered why some of the paint was flaking away, now I know.I have a minor gripe with the 22x fleet as well. The CrossCountry ones at least have this sort of cream-coloured enamelled coating on the seat backs and the fold down tray-tables. This chips off really easily, exposing the surface beneath, which is a much darker colour, and give the impression that the seats are rusting.
Also, something in their design has a resonant frequency which exactly matches the engine at one specific point in the acceleration, so every time the train accelerates, there is this buzzing vibration sound for a couple of seconds a certain amount of time after the engine revvs up. A very minor thing I know, but it gets on my nerves.
If those 180s don't have the silly metal screening in the windows (the stuff that blocks out RF and prevents a phone signal from coming through) then they're an improvement on the 22x, no matter what the rest of the train may be like... has anyone else checked this?22x were the UK's first go at a high-power underfloor-engined InterCity DEMU. It's understandable that there are shortcomings, and the 80x is a considerably improved version of the same sort of thing. (The least said about 180s the better).
2) The resonant frequency thing... I picked up on that straightaway, even when first using the 222s (the 220s and 221s also have it), and I couldn't pinpoint what was causing it... It's just a few seconds into the acceleration from stationary IIRC? Thanks for confirming that it wasn't me imagining things!
Hopefully the 810s are better than the 222s (when we get them in 2023).
