cactustwirly
That's incredibly poor driving advice. You should choose the gear based on the conditions and the ratios of the car (which is different for each gearbox)I've generally found that in most cars I've had it's easiest to drive in a given limit if you select the gear that is the first number of the limit. That is, 2nd for 20, 3rd for 30, 4th for 40, 5th for 50 and 6th (if you have one) for 60+. The exception is my present Kuga which has hellish turbo lag problems* if you use 6th for anything less than about 65 and gives you a very jerky ride on an undulating road, though it's fine if the road is totally flat. It'd be less noticeable on a traditional large-engined diesel, it's noticeable on this because it's a small engine (1.5) that couldn't pull the skin off a rice pudding until the turbo has spun up.
This is totally counter to what most instructors teach, and to what the flashing warning on the dash says.
* In essence, you're going along happily on the flat, the engine input is so low the turbo isn't spun up, you get to a hill and lose some power, it then takes about a second to get it back as it spins up then you get a nasty jerk, and repeat. Using a lower gear means more exhaust output, which means the turbo stays spinning and it doesn't happen. Even the aircon compressor kicking in is enough to cause it. Took me ages to work out what it was. It's the thing I most dislike about the car, which I'm otherwise very pleased with.
I can be in 4th at 30 mph, and I'll be there all the way to 50 if I want to make progress.
1st gear is very fierce in my car so you just use it to move off, 2nd till 17mph, then 3rd to about 27 mph. I can be in 6th at 50 very happily.
Other cars will be completely different
I have stop start too - it's called "turning the key"![]()
Mine doesn't have a key to turn
But then you lose the indicators and headlights...
