They have certainly been causing some pretty major grief in Scotland!
You would think with that and some of the problems with 380 at first Siemens must be experiencing squeaky bum time with a big order opportunity coming with Scotrail soon
Seriouly, however, given that London Midland has not had similar problems with their 350s nor SWT with the DC equivalents I think the first area to be looked at should be TPE's maintenance.
Given TPE's maintenance at Ardwick is carried out by Siemens Transportation Systems I don't think TPE can be to blame. Siemens have built the 350/3s and 350/4s as a side project while carrying out larger projects due to the order being so small so maybe they didn't dedicate as much resource the the 350 build as was required?
Seriouly, however, given that London Midland has not had similar problems with their 350s nor SWT with the DC equivalents...
Should also be clear there is quite a difference between a fleet delivered that has one or two out of service in a week with teething troubles, and a fleet delivered that is completely unavailable for service for months after delivery because of design/manufacturing flaws.
As an aside, how well have the various 377 add ons been interms of work out of the box reliabilitty?↲
Good point. I was aware of the /5s being a bit tempremental but think if the /6s and /7s were plagued with faults we'd have heard? I hope from a personal POV that we dont see 380 variants on the E and G etc.
However, the 380 reliability has been second to none in
ScotRail.
Perhaps TPE bought the wrong model of train.
I'm pretty sure there is a thread somewhere about the faults with the /6s! I saw two sets side by side both experiencing problems with the doors at Victoria a couple of months back and then after finally leaving Victoria it happened to another set at Clapham!
ScotRail.
When we had the introduction of 377/5's a lot of failures were not failures, in most cases it turned out faults could have been sorted by the driver but being new and not the usual 319 whack it and see, drivers were not 100% and were reluctant/ not sure what to do.
This maybe more of a problem for tpe as this is there first ac units and I bet a lot if not all drivers/conductors have never worked with ac units only diesel ( shouldn't be much difference between a 185 and a 350 on major components like doors).
377's use gps for door release and setting up the train at all locations, if it can't find a signal it has a hissy fit and won't open the doors, you then have to go through the emergency door release process. Now at Victoria if an arriving train has to emergency release as soon as the driver keys on at the other end all doors automatically shut and lock, the new driver then has to re release once the train is set up and knows where it is.
ScotRail.
I think its just normal refinement of new rolling stock, ironing out any bugs or reliability issues. Its more apparrent because they have a pretty high (perhaps mistakenly high) daily fleet availability requirement, particularly at weekends.
Did the 185s have any teething problems when introduced? I didn't use them before they started Blackpool and Barrow work but can't recall any problems in their early days working North West and Scotland services.
A bit off topic but would I be correct in thinking that the 377s GPS is affected by all the concreet etc at Vic?
