malc-c
- Joined
- 1 Dec 2017
- Messages
- 990
I'm in the process of fitting my linear servo point motors to my N gauge layout. Now partly my fault in that I drilled the hole for the wire slightly oversized in both the tie bar and the rack on the point motor, so there is a little play in the action, but when thrown the servo begins to move the point at a nice slow speed, but as soon as it's passed the point the spring comes into play and it snaps across. So I'm considering removing the springs on all the points. Either that or the tolerance for drilling the holes in the rack of the point motor and tie bar needs to be better so there is no play what-so-ever. My thinking is that with the spring removed the torque of the servo will hold the switch rails in place. Just interested in others opinions or comments. Granted it means that I would have to use the same set up if I ever ripped this layout up and started again, but is that really a problem ?
