With all CHX -> Hastings trains being cancelled today due to the land slip (at Wadhurst I think?)
That presumably means that some or all of the stock that would normally run that service is currently not required?
I assume the line will stay shut for some time until repairs are carried out.
Now additional to the above we have a blanket speed restriction expected later today resulting in extended running times which in turn results in reduced frequency which ultimately means some services will be cancelled.
Would it be possible to retask those "idle" trains to fill in the gaps as it were and hold the original frequency on other lines (or at least contribute towards doing that).
Obviously I am assuming that the stock can find another way around the closed track.
Or does the TOC take the opportunity to put the "idle" stock in early for routine maintenance while a window exists for free thus saving downtime on a later occasion?
Just a random thought I had
