Production of new DMUs has been curtailed due to environment/emmissions regulations. Small underfloor engines are not as efficient.
Have you heard of a company called MTU? lol
Like those under all the bi-mode IEP/80x series recently ordered?
Actually, once the TP north route is wired in time for the next franchise, it will be interesting if LHCS continues.
There should be several more-economic EMU/bi-mode solutions available by then.
I would imagine they could order straight EMU's by then and use the 802's for the still off wires sections.
I'm still slightly bemused as to why they choose Loco Hauled, rather than a single fleet of 802's? was it delivery time?
If they use the 802s for not fully electrified routes and EMUs for the rest what will happen when Newcastle services are diverted due to engineering works?
Did the 170s leave today?
I would imagine they could order straight EMU's by then and use the 802's for the still off wires routes.
I'm still slightly bemused as to why they choose Loco Hauled, rather than a single fleet of 802's? was it delivery time? was running 802's on purely Diesel too expensive? or did the DFT give the nod that some 68's would be used regardless probably with 442's but then First went one better and proposed new LHCS thanks to some cheapo Spanish junk.
Friday was the last day of them in service I believe.
Sam
They were due to do railtours over parts of the TPE network at the weekend.
It was lead time I believe.
Calling it "cheapo Spanish junk" is rather unfair.
I did hear (no idea how accurate) that MTU are running at full capacity and couldn't supply the engines required for either more Hitachi stock or for additional CAF DMU stock, in the timescales required.
Interesting. Are MTU the only possible supplier? Could Cummins not do something?
Sam
That was last weekend(9,10th July) , I was on it!
Sam
To me the logic would be driving first open with wheelchair space, a bay of Standard seating for accompanying passengers, and accessible bog at the inner end, then all the rest can be identical TSOs.
I noticed today that Wikipedia has a page for the "Class 397" CAF EMUs - not seen this used anywhere else - cites an article dated 16 Jul by Phillip Haigh
So we have classes 331 and 397 for two variants of Civity EMU from CAF, the only apparent difference being the top speed (100mph and 125mph respectively) and the interiors.
Not sure I see the numbering logic.
They also have to find class numbers for all the Stadler FLIRT variants for AEA.
The 397 is clearly a high-speed unit, with the 125mph top speed and a completely different streamlined front end to the regional 331 design. So it makes sense to put that with other high speed units in the 39x range to me.
Regarding the 600 series, that'd make sense for any large new DMU fleets perhaps?
The Sheffield tram trains were assigned 399 and only have a top speed of 100kmh.
Frankly after looking like there was going to be some order with the new number ranges its gone completely nonsensical again.
