Goldromans
- Joined
- 11 Feb 2017
- Messages
- 222
Do we know if ScotRail plan on ever re-opening the buffets on the HST's? I know there are power supply problems, but is there any timescale for their return (if they ever do)?
When they have enough hospitality staff, that's all I've been told.Do we know if ScotRail plan on ever re-opening the buffets on the HST's? I know there are power supply problems, but is there any timescale for their return (if they ever do)?
At least that's a when and not if! Do we know if the new staff are being trained on the buffets right away or just trollies?When they have enough hospitality staff, that's all I've been told.
That specific detail wasn't mentioned in the reply I was given, the rest simply said:At least that's a when and not if! Do we know if the new staff are being trained on the buffets right away or just trollies?
There is currently no timescale to resume the use of the Café-Bar buffet counters on our
HST sets.
I did notice on the ScotRail jobs website over the last few weeks that a few catering and hospitality positions have opened up. Hopefully a positive sign of things to come!When they have enough hospitality staff, that's all I've been told.
I don’t think we will ever see 20 diagram, it’s just impossible to achieve on the fleet. There’s short forms and DMU subs pretty much daily these days covering for HST failures/ unavailability.Also did the number of daily diagrams stay at 15 or increase to 20, which I believe was a plan for the May timetable at one point?
Probably not without breaching a company policy. The facts are there to see on RTT on a daily basis. You can see the various short forms and subs in place of the booked HST set. The fact I don’t like HSTs is neither here nor there. I don’t like them because it causes the paying public no end of hassle and disruption on a daily basis. We need a more modern/reliable fleet on our Intercity network for the customers sake.I'm still waiting to hear some details of the failure reasons, any trends etc.
Do you have anything to share?
It's clear you don't like the HST, but some facts would help inform the discussion.
Intransigenceany trends
I think what some of us are interested in, but probably will never be able to know, is whether the main problem is really to do with the trains themselves or whether it's to do with inadequate supporting infrastructure, maintenance and so on.We need a more modern/reliable fleet on our Intercity network for the customers sake.
Maintaining these same HST fleets to a more than acceptable reliability standard was not a problem for the depots used by FGW, LNER, XC and EMT so the question needs asking why Scotrail depots are consistently failing to turn them out to anything close to an reasonable level.
As an insider I get the impression your not too far wrong.Ive had the feeling for a long time of a lack of will in regards to the implementation of the hst when it hit home the time,effort and loads of money required., it's certainly easy to get the impression that the whole project has been under-resourced and/or incompetently implemented, or even sabotaged...
I see photographers eagerly capturing the CrossCountry HSTs running through South Yorkshire, seemingly reliably, every day as they take over 8 hours to run between Edinburgh and Plymouth. Perhaps that's part of the issue. They were designed to run at up to 125 mph on longer journeys. With XC they still do, and with 7 coaches.Maintaining these same HST fleets to a more than acceptable reliability standard was not a problem for the depots used by FGW, LNER, XC and EMT so the question needs asking why Scotrail depots are consistently failing to turn them out to anything close to an reasonable level.
The Scottish HSTs are maintained at a depot which has never maintained them before.
It’s simply experience, the fleets you mention were maintained at HST depots which have been looking after them since their introduction.
Thanks for that.As for the power cars I've had no trouble with them and they are in a much better condition than when they first arrived. Wheel turning continues to keep sets out of traffic as moving sets to Shields is a convoluted process requiring sets to be split. The wheel lathe is on the wrong side of the wrong city and can't accommodate a full set. An poor oversight by the bid team all those years ago. Hope this helps.
Yes the ATP equipment is long gone, so at least that's not a problem anymore.Internal sliding doors seem to be an issue common across the GWR, XC and Scotrail fleets.
They were never tip top reliable in slam door days, but nowhere near as bad post works.
Indeed I recall some of the XC sets had them isolated not so long bag with a big sticker saying 'do not reinstate - warranty repairs' (or similar). Given how frequent the issues are, you can't help wondering if its poor design.
Has the ATP equipment been taken out the power cars now? If I recall correctly that was an issue in the early days?
(Thank you @scotraildriver for some of the insight, much appreciated)
It should be noted that improved wheelslip/wheelslide protection was part of the original project scope for when the power cars went through Loughborough. It was de-scoped, presumably for cost reasons. It is a false economy as it means wheelset life remains shorter and tyre turning is more frequent, even before the benefits in terms of safety and ride quality.
2.2 High-speed Train (HST) modifications: paper 2004-02
David Lister presented this paper, reminding the Board of its previous decision at the meeting on 23 March to approve the replacement the HST power car wheel slip protection (WSP) system and its request for a review of the additional opportunities to improve the HST fleet performance and availability including the cost and benefits of implementing double variable rate sanders (DVRS) on HSTs.
The Board noted that the long-expected timescales meant that no decision was required until after the initial group fleet strategy had been formulated and the Carmont Rolling Stock Steering Group recommendations were known in a few weeks’ time, and therefore concluded that those should be considered with the options presented.
The Board requested that ScotRail’s engineering team update the Board annually on its strategy plan.
The Board requested that the incoming non-executive director chairing ScotRail’s Safety, Health, and Environment Committee be briefed on matters relevant to the HST fleet.
Improved WSP, they do have such a system but I'm not sure whether they are all the original Girling or if some use the later and better BR designed system (fitted to the WoE batch HSTs and Mk3Bs, plus the entire Irish Rail Mk3 fleet, from new.)WSP is being added, as per the 20 April 2023 ScotRail board minutes:
