Services with the most "train reverses here"
Tomp94
9 May 2019
Anyone know which passenger services have the most change of ends for a driver?
lxfe_mxtterz
3 Mar 2018
Sarahdale (West of Emmerdale)
I think we've done this one before.
The most I can think of is the South Western Railway service from London Waterloo to Corfe Castle - four changes of ends: at Yeovil Junction, Yeovil Pen Mill, Weymouth and Wareham.
Not sure if it's the same driver throughout, though.
Taunton
1 Aug 2013
The 1960s dmu service from Scarborough to Middlesbrough also had four reversals, in a relatively short run, just outside Scarborough station, twice at Whitby, and at Battersby.
Personal record was three, Edinburgh to Taunton, at Carstairs, Birmingham New Street and Gloucester. But again, long ago.
March thread about reversals en route, on a quick scan through that SWR service mentioned by @lxfe_mxtterz wasn’t ever beaten:
godfreycomplex
23 Jun 2016
It wasn’t, no. Changed at Salisbury and Weymouth I believe.
In terms of a driver diagram it’s probably Stourbridge. With mainline TOCs I’m not sure but Windsor & Eton Central drivers are allowed to do I think 10 round trips so that’s 20 (well, 19) end changes.
Neptune
29 May 2018
Stourbridge Town - Stourbridge Junction ?
Have I misundestood the aim of this thread? I read it as being reversals on one service (ie reversals for an end to end journey with one headcode). Each service has a different headcode. I’m sure the crew diagrams have many diagrams but on one headcode per journey.
In my railway career the most I’ve had was Selby to Wakefield with reversals at Bradford Interchange, Huddersfield & Wakefield Kirkgate.
QueensCurve
22 Dec 2014
Not a British example, but the service I took 3 between 1966 and 1981 from Calais as far as Innsbruck reversed several times. Ones or twice in Northern France during the night (I don't recall which or where), plus Zürich, Sargans and Buchs.
There is now a new route at Sargans which obviates reversal there.
miklcct
2 May 2021
Cricklewood
What's the point of having services which reverse mid-way? Aren't such services inefficient because a reversing train blocks the line for a long time?
Neptune
29 May 2018
But how do you serve stations like Bradford Interchange or Castleford or any other number of stations where a reversal is necessary to provide a service to that station?
miklcct
2 May 2021
Cricklewood
Bradford Interchange is clearly not suitable for multi-line operation as there is a section with 2 tracks only, which limits the capacity.
Neptune
29 May 2018
Services at BDI can arrive simultaneously and since the last remodelling depart simultaneously.
Not every junction faces the right way. DMU and EMU operation makes it easy to reverse direction en route in just a slightly longer than normal station stop. I suspect this allows for through services that would never have been attempted in the days of hauled stock.
The exile
31 Mar 2010
Somerset
Because you have major city stations which are dead- end termini, but people want through trains. When these were built, steam locomotives had limited range and putting the replacement engine on the other end and going back out the way you had come was often at worst no slower than replacing a loco at the same end ( still applies where a change from electric to diesel is required). Many of the “record holders” in terms of numbers of reversals are “ once a day type services” (like the Scotland - Southwest train that would reverse at Edinburgh, Carstairs, Birmingham and Gloucester) or overnight trains, where the rationale for providing through services despite multiple reversals should be obvious. The Germans are slowly trying to eliminate their dead- end stations, but it’s a very long and expensive job.
Mcr Warrior
8 Jan 2009
Be tricky for a XC service from Birmingham New Street (to say somewhere on the South Coast such as Bournemouth) to call at a principal intermediate station like Reading without any reversal being necessary. :rolleyes:
The default reversing allowance for most units is 3 minutes (it's obviously more for longer trains). That's not much more than the 1-2 minute minimum dwell you might expect for a reasonably large station.
Obviously it's always better to avoid reversals where possible but there's no choice if you want stations like Bradford Interchange to have through services.
Kite159
27 Jan 2014
West of Andover
Ah but in other countries those stations won't exist with XC serving Reading West etc ;)
The exile
31 Mar 2010
Somerset
Oh, I don't know! Banbury - Bicester - High Wycombe - Greenford - Hayes & Harlington - Slough - Reading! Would take ages, deprive Oxford of connections to a lot of the country, but it would save blocking one of Reading's platforms for 5 or 6 minutes, and thus be so much more efficient (on paper). (Irony button "off")
In most cases, stations where many services reverse have track layouts specifically designed to optimise reversal and the reversal takes very little longer than a rather leisurely stop. In fact, I'm often left thinking that punctuality would benefit if reversal stops were actually given longer!
As indeed used to be done with Saturday extras that were basically there to soak up the demand to stations other than the one where reversal took place. Still a (rare) feature at Reading and Bristol into the 1990s.
507020
23 May 2021
Southport
The Lancaster - Morecambe - Heysham Port has to reverse at Morecambe, but in the previous timetable until 16 May there was a return Heysham Port - Morecambe - Carnforth - Lancaster service with 3 reversals. With the 2 services operating back to back, this necessitated 5 reversals in the space of an hour!
The exile
31 Mar 2010
Somerset
The answer will often lie in that word “service”. Any service provision will involve balancing “efficiency” with providing a service that actually satisfies customer demand. The two will often conflict.
