Turbostar
Hi all. I downloaded the SVR at the weekend, and was wondering if there's a fix for the download version, as there seems to be only an update for the cd version. I contacted Just Trains, and they told me the download version is updated, but I'm still finding problems with it, and am not getting much response from JT at the mo. So far, there's a problem with points not working when you switch them (you still go in the direction you want, just that you don't see the points move), when you press 'Escape' to come out of the route, it's just blank, instead of having the three options (save, return to route, exit), and I can't edit any of the route in the editor & tools program (Route Editor), as it just comes up with an error every time (Error reading editor object selection file severn_valley1.ref - Line: 0). I've got the West Somerset Railway as well, and had no probs with it whatsoever. Both are cracking routes, just seem to have a bit of bother with the SVR. Has anyone else downloaded the SVR, instead of purchasing the cd version, and had problems with it, and is there a cure? Thanks in advance.
