swt class 450
Guest
- Joined
- 9 Apr 2016
- Messages
- 1,909
I am wondering should London Kings Cross and London St Pancras be combined in to just one station called London Kings Cross St Pancras International instead? What are your thoughts on this?
Personally i think it is rather silly that they are both considered two separate stations when they are right next to each other and are really basically the same station. You can easily walk from the platforms in Kings Cross to the platforms in St Pancras in less than 60 seconds. You can even walk between the two of them without going outside. Also they even share the same London Underground station.
What i am thinking is that they should just be considered to be the same exact station called London Kings Cross St Pancras International and the platforms should be renumbered so that they are in the same series without duplicate numbers.
The platforms could renumbered like this for example:
• 1 to 12 - East Coast Platforms
• 13 to 15 - Southeastern Platforms
• 16 to 21 - Eurostar Platforms
• 22 to 25 - East Midlands Platforms
• 26 to 27 - Thameslink Platforms
• 28 to 29 - LU Circle Line Platforms
• 30 to 31 - LU Northern Line Platforms
• 32 to 33 - LU Piccadilly Line Platforms
• 34 to 35 - LU Victoria Line Platforms
I am thinking that considering them as one station would also make things a lot easier and simpler for passengers. Many passengers who are changing trains might not even realise that they are right next to each other. Also it would add less confusion for passengers travelling to the Cambridgeshire and Hertfordshire areas as trains for these stations can now depart from both stations before joining up and following the same route at Finsbury Park station.
They are basically the same station so they should make this clear to passengers by making it one station with one name instead of two stations with two names.
What are you thoughts on this idea? I would be interested to hear any views on what you think of this?
