Usually driving on a maintenance depot
Every depot usually has the following:
Arrival roads
Fuel point
Maintenance Shed Roads
Holding Sidings
Carriage Sidings
The role will involve driving trains between all the above. Usually you drive between roads via a Shunt neck at each end of the depot.
The role will also involve:
Pulling points
Regular Communication via hand held radio
Fault fiding
Train Prep
Moving/assisting failures and units "under repair"
Fuelling
Tanking
Thank youI used to be a Shunt Driver so let me know if you've got any questions on any specifics
