It's not actually TPE that have come up with that marketing, it's the Transpennine Route Upgrade which is DFT/Network Rail. They've also started with TV adverts which depict a model railway which is what I think they are trying to show in that picture. There is also a giant boot and map in the picture that isn't true to life either!It seems TPE have come up with a new design for overhead electrification. It might not however reduce the rate of pantograph entanglements. Photo taken at Manchester Piccadilly:
Not quite - there is a crude model of a pantograph on the back end of the 2nd coach.No pantograph entanglements there. The train appears to be a diesel under the wires.
Looks like an electric heater for keeping the sheep warm in winter!I know one shouldn't over-analyse humorous pictures like this, but can anyone work out what the object in the foreground field is meant to be? It looks to me like a giant three pin plug attached to two electric flexes, but why? (and if not, what is it?)
Is the field supposed to be an electric blanket?I know one shouldn't over-analyse humorous pictures like this, but can anyone work out what the object in the foreground field is meant to be? It looks to me like a giant three pin plug attached to two electric flexes, but why? (and if not, what is it?)
Hmm, yes, could be either of those. No wonder English lamb is expensive, especially at current electricity prices .Is the field supposed to be an electric blanket?
It’s one of those adjustable plastic loops, presumably for the other boot. I’m not sure what you call them, but you press down on them and pull them along the lace, having the effect of tightening.I know one shouldn't over-analyse humorous pictures like this, but can anyone work out what the object in the foreground field is meant to be? It looks to me like a giant three pin plug attached to two electric flexes, but why? (and if not, what is it?)
Which one are you suggesting that was?There was a OLE design competition some years ago with some beautiful but in many cases totally impractical submissions. The holy grail - as always - was light, simple and unobtrusive (ironically everything that Series. 1 ain't).
Gallery of Entries | Aesthetic Overhead Line Structures
Aesthetic Overhead Line Structures Design Competitionwww.ribacompetitions.com
Patent Pending
As part of the UK’s signature high-speed rail project, Moxon, working in conjunction with engineer Mott MacDonald, has designed sleek and cost-effective integrated overhead line structures (OLE).
A clever innovation has allowed for the design to take a reduced profile, minimising visual clutter. Using composite materials with intrinsic electrical insulation properties, the structural and electrical protection requirements have been combined in a single new cantilever component. This eliminates the need for visibly obtrusive ceramic insulating pots.
The complexity of the structure is thus dramatically reduced, with a 70% reduction in part count relative to existing OLE systems, speeding up installation times and reducing whole life cost.
The reduction in height and overall lessened visual impact makes these OLES appropriate for sensitive sites while maintaining full interoperability with all other high speed OLE systems currently on the market.
Ah, good call - it doesn't seem to match the lace on the other boot, but I think you're spot on.It’s one of those adjustable plastic loops, presumably for the other boot. I’m not sure what you call them, but you press down on them and pull them along the lace, having the effect of tightening.
The VelocitY option appealed to me on the above grounds. The problem would be the small matter of the tracks being too close together to allow for the centre-spread configuration.Which one are you suggesting that was?
I’m guess from the description though it was impractical because it’s simple design.
Many thanks for that. I didn't know they had actually created a real-life installation. I'm no OLE engineer, but I would think that the straight registration arm (no lift without catching the pan) and what looks like some issues with adjusting height of the cantilever might cause problems when released into the wild.From the final shortlist Moxon eventually won the competition and in 2018 prototypes were built in conjunction with Mott McDonald. Bear in mind this was approaching six years ago..anyone know if these will actually be implemented on any HS2 sections?
https://moxonarchitects.com/projects/518-integrated-ols
The Moxon page from the link shows another installation featuring a standard Series 1 F&F angled arm.Many thanks for that. I didn't know they had actually created a real-life installation. I'm no OLE engineer, but I would think that the straight registration arm (no lift without catching the pan) and what looks like some issues with adjusting height of the cantilever might cause problems when released into the wild.
Ah - thank you.The Moxon page from the link shows another installation featuring a standard Series 1 F&F angled arm.
It's a still from a short video ad on the upgrade project. Looks like a mix of 00 gauge and cheap cg though I could be wrong.
I mean the wire is threaded through the head span, so approximately 0mph.What is the top speed of such simple tramway style overhead electric line in realistic? 25mph?
The northern 331 is an attempt at one based on a bachmann 150. If you look closely at the underframe, doors and roof you can see the origins. The double windows is where they've added a divider to the centre of the 150 windows to give it a more civity look. No idea how they did the middle vehicle, though.
