Single track lines where a physical token is in use
Andyjs247
1 Jan 2011
North Oxfordshire
Hi all,
Apart from preserved lines, most single track lines these days seem to use an electronic token or some other form of virtual token rather than a physical tablet / staff etc. which is carried on board and exchanged with the signaller at the end of the single line section.
Seeing the thread on semaphore signals, I'm sure there must be some routes on NR which still use this method but I'm struggling to think of any. Are there any passenger lines where the train must stop or at slow down so that the driver can exchange the single line token?
gazthomas
5 Jun 2011
St. Albans
Hi all,
Blaenau Ffestiniog line - two blocks with tokens at Llandudno Junction and Llanrwst North.
Murphyen
4 Aug 2009
Harrogate - York: again two blocks between Knaresborough and Cattal, and Hammerton and Poppleton.
mallard
12 Apr 2009
St. Erth - St. Ives. Quite nice when you're on the first train of the day (which sets out from Penzance) and you see the driver take the token from the signalman, a scene that has probably barely changed since the days of steam!
IanXC
Emeritus Moderator
18 Dec 2009
I can't quite remember the locations of the sections and boxes, but physical tokens are exchanged on the Cumbrian Coast Line, and the Barton on Humber branch too.
VicGreen
2 Jan 2013
Token exchanged at Oxmarsh Crossing ,New Holland for the final single track to Barton
Cherry_Picker
18 Apr 2011
Aylesbury to Calvert certainly used to be until Aylesbury Vale Parkway opened, it might still be in fact but token machine isnt at Aylesbury station any more.
CC 72100
23 Jan 2012
Newquay branch? Got a feeling I saw what looked like a Token passed over at 'that junction beginning with B who's name I can't think of right now'.
Also, what looks like a physical token is handed to the driver just after Crediton, on the Barnstaple line.
matchmaker
8 Mar 2009
Central Scotland
Kilkerran - Stranraer. The line also features the only surviving Tyers No 6 Tablet instruments on NR (all other token working is by Tyers No 9 Key Token instruments)
Crossover
4 Jun 2009
PR1Berske:1316021 said:
Preston-Ormskirk line if I'm not mistaken
It was when I was there a few weeks ago. There is also one at Bare Lane I believe, for access to the Heysham Port branch
themiller
4 Dec 2011
Cumbria, UK
Tokens are in use between Sellafield and St Bees. I'm not sure about he section between St Bees and Whitehaven (Bransty). The single line section from Parton to Harrington has no physical token.
Sidious
11 Jun 2012
Gunnislake branch - the driver has to take the token out of a cabinet at St. Budeaux Victoria Road station.
Captain Chaos
31 Jan 2011
Maidenhead - Marlow branch has a Token for Maidenhead - Bourne End and a Staff for Bourne End - Marlow
DavidBrown
29 Mar 2011
North Devon
Yes, infact there are two token sections on the Barnstaple line - Crediton to Eggesford, and Eggesford to Barnstaple. There also used to be a token for Crediton to Lapford when freight traffic was still heading there, but that's long gone now.
Marton
9 Nov 2008
The Esk Valley line (North Yorkshire), unless it has changed recently.
Not changed recently, but only token from Nunthorpe. Middlesbrough to Nunthorpe is TCB. see http://www.networkrail.co.uk/browse...x/london north eastern sectional appenidx.pdf page 829/1028
Sections with tokens are
Nunthorpe - Battersby; Battersby - Glaisdale; Glaisdale - Whitby.
All but Nunthorpe are driver operated cabins, with, I believe, a cabin at Grosmont to enable the NYMR to access the token
jnjkerbin
25 Apr 2012
Down south
According to the latest issue of Rail
At Goonbarrow Junction, the Electric Token working used on the section from St Blazey is replaced by a Train Staff to Newquay.
rebmcr
15 Nov 2011
St Neots
What happens if a train wants to follow a previous service through a token section?
Does it have to wait for something to come back the other way? Are the sections short enough for the signaller to run the token back to the start? Are these only used at the termini of lines?
rownd
28 Jul 2012
Midlands
Preston - Ormskirk is covered in three sections:
  • Farington Curve - Midge Hall: Track Circuit Block from Preston PSB
  • Midge Hall - Rufford: Electronic Token Block
  • Rufford - Ormskirk: One Train in Section, using a wooden staff kept at Rufford crossing box
causton
4 Aug 2010
Sometimes there are multiple tokens available from a machine, but only one issued at once. See page 10 of the report on http://www.raib.gov.uk/publications/investigation_reports/reports_2008/report132008.cfm for an example picture of one!
(the above sentence was based on the RAIB report and I have no other knowledge of how the tokens work)
PR1Berske
27 Jul 2010
Cheers :)
There will always be one passenger I notice.who had never seen it before, asking someone why it happens sometimes :)
