Single-track station on double-track railway?
fishwomp
5 Jan 2020
milton keynes
No, both Corby and Malton are double tracked through the station. The OP is asking for examples where the whole line is singled though a station.
Malton is as good as single track: nothing uses the other. A track that isn't used is rather similar to it not existing at all.
There are some light engine paths that do not stop but they don't run at all since the 68s finished, probably didn't run often before that either.
You could argue that the deep level Merseyrail Loop line is an extended version of a double-single-double layout, with 3 stations on the single track section.
The single track leaves the double track at James St and rejoins it two miles later with Moorfields/Lime St/Central platforms en route.
snowball
4 Mar 2013
Dore & Totley, although that will change soon.
Surely that doesn't count as the OP intended. If you go through from Manchester towards Sheffield, the track reduces to single before the station, but does not return to double after the station, unless you include the MML.
Mojo
7 Aug 2005
I also seem to remember Princes Risborough only having one platform a decade or so ago.
Technically it had two, with a bay as well as the single through platform.
The second through platform at Princes Risborough was reinstated some 25 years ago, in 1998.
And in any case you could argue it doesn’t meet the requirements for the thread as it was not a single through platform on a double track line, but only ended up like this when the line was rationalised to make it single track between a point just south of Princes Risborough (save for a rather pointless loop just off the platform at Princes Risborough and another one at Bicester North).
PyrahnaRanger
16 Aug 2022
Lancashire
Maryport doesn’t become a single line either, although trains in both directions do use the same platform - the Carlisle->Barrow line continues through on the east side of signal box, while the line in the Barrow->Carlisle direction continues through to the west of the signal box. Trains in either direction divert off to the single platform though, so not sure if this satisfies OPs requirements? Not sure if it’s supposed to happen, but you’ll quite often have a Barrow bound train have to wait for a Carlisle one to clear the station.
I understand that the second platform is being reinstated.
Dunbar was two platforms on the main line then the down platform abandoned and then reinstated.
Hartlepool second platform reinstatement is almost complete. But the track there isn’t singled. Was it ever?
The tracks through Dunbar were not singled. Are we getting away from the original question now?
D6975
26 Nov 2009
Bristol
Ulceby isn't single track through the station. It's double track but only has a platform on the East side. Northbound trains run wrong line for a short distance to access the platform.
Marton
9 Nov 2008
It’s actually the third platform. Platform 1 is a bay used on Sundays for the Darlington service.
2nd through platform then… :D Doesn’t affect the fact that it’s not what the OP was actually asking after…
Ayrshire Roy
8 Feb 2019
And West Kilbride! Which are an unusual situation in regard to the OP's question, as although there is double track through both one-platform stations, only one line is electrified and used by passenger trains.
Are the two lines there not classed as two separate branches that run side by side, one to Hunterston and one to Largs?
domcoop7
15 Mar 2021
Wigan
Would the likes of Orsmkirk and formerly Kirkby count? Double track right up to the station but single track bidirectional for the platform. At Ormskirk this is just for the Liverpool bound side, for the Preston side it's strictly a single line. Kirkby had two separate bidirectional lines for both directions. I'm not sure where the line on the Wigan side of Headbolt Lane (which is single track bidirectional with a token) splits back into two way running, but maybe that counts too?
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
No; The electrified line is the Up and Down passenger line, and also carries Down freight trains, the non-electrified line is the Up freight line. Since the demise of Ravenscraig and Hunterston however the freight capacity is hardly used!
There have been calls locally for half-hourly trains to Largs, which would be great, but would require a lot of investment; Electrifying the Up freight line and rebuilding the Up platforms at West Kilbride and Ardrossan Sourth Beach.
_toommm_
8 Jul 2017
From re-reading the original post, it seems I got the wrong end of the stick. I thought the question was a single-platform station on a double track.
Krokodil
23 Jan 2023
Wales
Everything is going in the same direction though.
Pontypridd has an interesting history, it had a total of seven platform faces on the same island. Post Beeching only one platform remained in use along with a goods line . By the eighties that single platform was handling more traffic than the rest used to between them so it was decided to build a new platform - not reinstate one of the six disused ones but build a new platform on the goods line. It was cheaper to do that than to remodel the track layout.
DesiroUK
21 Jan 2024
Grimsby
I have a mate who lives near Ware station and I believe the story for the current arrangements dates back to when the line was built and whoever owned the road over which the line crosses via a level crossing immediately to the north of the station would only allow one track to cross the road.
61653 HTAFC
18 Dec 2012
Another planet...
It would appear that there are no examples of what the OP is asking for. Navigation Road is probably the closest match (if you ignore the Metrolink).
androdas
3 Aug 2011
South East Northumberland
Bedlington in its original form, The colliery was opposite so prevented a second platform on the main line, it did have a bay facing Ashington / Newbiggin, so had more than one platform just not on the through lines. Its currently being rebuilt for reopening as a more conventional 2 platform station and a car park is being constructed where the bay was.
norbitonflyer
24 Mar 2020
SW London
The Thameslink part of Wimbledon seems to fit. Double track on either side, but single track through the station, where both directions use platform 9. The opposite face is used by trams.
Railsigns
15 Feb 2010
Ware (post #10) is exactly what the OP asked for. A double track that reduces to single at the station, then goes back to double. No other complications such as junctions nearby or other lines running past the station.
61653 HTAFC
18 Dec 2012
Another planet...
Oh I missed that one. Thought we were going to have a rare example of a trivia thread with no valid answers!
DesiroUK
21 Jan 2024
Grimsby
Strictly speaking, if what my mate in Ware told me is correct, then Ware is not single track as a result of "physical constraints or so that passengers don't have to cross the line" but rather as a result of landowner agreements, and thus does not fulfill the OP's requirements.
scrapy
15 Dec 2008
Earlestown (when going Liverpool LS to Warrington BQ and vice versa) and Shipley (when going Skipton to Bradford FS and vice versa) the line goes from double through the station to a single bi directional line then back to double.
Krokodil
23 Jan 2023
Wales
That sounds like a constraint to me.
greyman42
14 Aug 2017
Might there be a station on the York to Harrogate line which meets the criteria?
_toommm_
8 Jul 2017
Unless mistaken, all the stations between York and Harrogate still have double platforms in regular use.
I concur, as someone who lives on the doorstep of the line. There are single track sections, but no stations with just one platform.
