centraltrains
West Midlands Railway have posted quite detailed and insightful responses to frequently asked questions in their latest Snow Hill Line updates.
However in response to "Why can’t we timetable more services and longer trains?", we learn the intention is not to return to the pre-covid 6 trains per hour frequency.
Summary:
In Full:
This is deeply disappointing as it means the Whitlocks and Dorridge branches will retain a disappointing 2tph frequency, although balanced out to more even gaps in the service.
To me, pre-covid, every 20 minutes was just about frequent enough to use it as a "turn up and go" service, but half hourly thoroughly exceeds this threshold.
I imagine with the other operators involved, it would be very hard to revert these changes in the future back to 6tph through the core.
This is a very backwards step compared to the 2018 30-year rail strategy vision which proposed increasing the branch frequency to 6tph.
To me, living on one of the branches, it feels like a vote of no confidence in the recovery of the lines, thus I will most likely mitigate the inconvenience this poor frequency locks-in brings by learning to drive.
The current improved concept is to maintain a 4tph base timetable in the medium to long term but rebalance it to a 15 minute service frequency alongside other operators
In Full:
You said …
“7.56 Stourbridge to Snow Hill only has 4 carriages. I just missed the 7.30 train (not your fault) and had to wait 26 minutes for the next one. Please run more services and/or run services with more carriages on them at this time.”
“WMR strike again, 3 carriages on what I recall used to be a 6-carriage train before Covid???”
“Why are you now running 3 carriage trains in busy periods, 6 should be the minimum”
“The 16.24 to Kidderminster is now 3 carriages. It's the busiest service of the afternoon as far as I can see and always a squeeze to get on. Why not increase the carriages to this service and reduce the amount of carriages for the next service?”
Our response: Our current Snow Hill lines base timetable is designed to deliver four trains per hour (tph) through the core section in each direction on weekdays. With 2tph to/from Stratford upon Avon and one each at Dorridge & Whitlocks End in the east, and then 2tph to/from Worcester and 2tph to/from Kidderminster on the western leg of the route. As detailed above, each of these services is covered by 13 actual trainsets which run back and forth each day like a pinball from one end to another. However, the base concept of this timetable is based on is our pre-covid 6tph operation. Effectively, as customer numbers dropped and crew shortages began to bite during the early stages of the pandemic, we had to strip back services by removing circuits and from the existing 6tph / 10-minute frequency core timetable. We were not able to unilaterally redesign our timetable as our services are interwoven around other long-distance express and freight trains. In effect, we are currently running a 6tph timetable, with 2 services removed, rather than a timetable which was designed for 4tph.
We have also been sharing the remaining available train carriages with other operators while various new train fleets have met with manufacturing delays. With fewer carriages to play with, traincrew availability challenges and changes to commuting patterns, this has meant that for much of the last year we have operated a 4tph service, but within the constraints of the old timeslots – or paths – being designed for a 6tph operation.
This leaves some 20/40 minute gap in frequencies where they used to be 10/20 minute. Again, we understand this is not ideal and can dissuade customers from coming back to travel by train. With a better understanding of the returning commuter patterns, as well as timescales for our new trains coming online over the next year, our timetable strategy team have been working on a complete overhaul of the base route timetable alongside Network Rail and Chiltern Railways. The current improved concept is to maintain a 4tph base timetable in the medium to long term but rebalance it to a 15 minute service frequency alongside other operators. Fundamentally, this allows us to implement a consistent five-carriage allocation for all services, rather than the current mix of train lengths. It also means more resilience can be built into the operation, such as increased turnaround times at places like Kidderminster, which means any slight delays in one direction are less likely to impact the return journey. The new timetable is still in the design phase and will go through an industry validation process, which involves checking there are no conflicting train paths or calling patterns. We will also consult customers and stakeholders before introducing any changes to make sure that they work for as many people as possible.
