the plans were drawn up by the Burns Commision established following the scrapping of plans for an M4 relief road south of Newport
Interestingly the Burns Commision appears to propose abolishing the distinction between 'main' and 'relief' between Cardiff and Severn Tunnel Junction with the top pair of lines west of Bishton flyover (currently the mains) being mainly used for local, commuting services in future. The bottom pair of lines (currently the reliefs) would be mainly used for inter-city services. The Burns Commision report points out that "This configuration would allow for other branch lines to connect to the main line, such as the Ebbw Vale and Marches line" however it does not say what would happen to freight services. Would mixing freight and InterCity services on the current relief lines work?
Perhaps someone can confirm, but the illustrations of the new station proposals in the consultation document appear to have the platforms suituated on what are currently the releif lines. If I'm correct, that means the platforms will be in the wrong place if/when the Burns Commision proposals are implemented, since only fast passenger (non-stopping) and freights would then be using those lines.
Good to see this starting to move forward. Any additional services need to run through from west of Cardiff. Cardiff Central already struggles to cope with the number of terminating trains, as discussed elsewhere. When the tfw Cheltenham goes to a regular hourly service, perhaps it could interwork with the Swanline to avoid terminating services and provide east-west connectivity across Cardiff with the proposed new stations.
As noted above, there are plans to upgrade the relief lines to for frequent use by passenger services. Since the GWML west of Cardiff is only double-track, there is not the capacity for everything arriving in Cardiff from the east to continue west along the main line - at least not if you want to be able to give Pontyclun, Llanharan and Pencoed a decent service. I think providing much of an uplift in services between Cardiff and Bridgend will need an infrustructure upgrade. Building a new station on this stretch (perhaps the Miskin one mentioned in KeolisAmey's franchise announcement) with platforms off the main running lines (so that stoppers can be looped for fast trains to overtake) is probably the least expensive option to acheive that.
I would certainly support the (hourly) Swanline service running through to either Cheltenham or Bristol though, and additional services as soon as the capacity issue(s) can be resolved.
I wonder what is happening regarding the Cardiff Parkway station proposed for the St.Mellons area? This is part of a bigger scheme put forward by a developer who would like to build a business park at the location. Friends of the Earth and others objected and the Welsh Government ‘called in’ the scheme over 1 year ago since when, we have heard nothing.
I think Cardiff Parkway is/was intended to have four platforms; I'm not really in favour of that idea as I feel strongly that
only the stoppers should call and not fast/semi-fast trains to London, Manchester, Chester, Portsmouth, Nottingham etc. so only needs platforms on whichever pair of lines becomes the one for stoppers. That said, at least 4 platforms would be future-proof if, when the relief lines are upgraded to passenger speeds, they decide to change which pair of lines is used for what.
Tfw saying trains will have level boarding so expect more class 756s.
TfW might not actually need to do anything fleet wise. If the Bristol services end up being run by GWR then in the smallest option TfW might only need to add calls to their existing Cheltenham services, which are already planned to be 231s so level boarding would be provided without any change of TfW fleet. If I recall correctly only 1 GWR service per hour calls at Patchway and that is the Cardiff-Penzance service. If this was still just Cardiff-Taunton and worked (or expected to be) by class 165/166 units I wouldn't have been surprised to see the proposed new stations added as additional stops on that service and no additional services provided by either operator.
Surely capacity through the Severn Tunnel would hinder additional stopping trains being introduced through there?
As I understand it, only one train is allowed in, in each direction. 2 GWR Padds, 2 GWR locals and a freight per hour in each direction pretty much fills up paths.
That is 5 trains per hour. The tunnel can take more than that. Severn Tunnel East to West is timed as absolute block with 2 minutes bunce on top (it probably doesnt need as much as 2). A GWR 800 can traverse the tunnel in 3½ minutes, so its a 5½ minute headway for those. A 165 takes 4 minutes, so a 6 minute headway. A Class 4 takes 4½ normally, a 2200 ton Class 6 takes 6 minutes, so a 8 minute headway. If you assume the above and a class 6, that is 31 minutes of the hour used.
Looking at an old PDF 'Rules Of The Plan', headways through the tunnel appear to be 5 minutes (12tph?) unless following a freight (6 minutes) or 7 minutes if following a freight that has been or will be looped in one of two places.
Here's a question could more freight be routed via Gloucester as most of it isn't highly time sensitive?
Doesn't most freight already go via Gloucester to avoid steep gradients in and out of the tunnel?
surely Severn Tunnel Junction-Cheltenham/Gloucester-Swindon electrication is a priority.
It should be, but that's because things like Didcot-Oxford-Banbury-Coventry should have been done by now. Since they haven't been done, they are the priority for electrification.
Newport re-signaling is only around 12-13 years old, so no one is going to make any significant changes.
Except that, as I have discussed above, there are now plans to use the relief lines for passenger trains much more often.
