At King's Cross, if you are a departing passenger, one trick that will make your day slightly more pleasant is to access the platforms (0—8) via the mezzanine walkway (passing by the first class lounge) which offers direct access to these platforms. If one were to embark on one's train via this route, one would avoid the hustle-and-bustle of the ticket barriers of the station on the ground floor.
If you are an onward passenger at KGX, headed for the underground, always turn left! This will enable you to avoid the warren of KGX underground station, and access your tube most directly via the old ticket hall.
Does anyone else have any similar such tricks for any stations across the nation? I spend a lot of time analysing station plans and would love to know more!
Thank you!
Thank you!
