Stations which could be joined together to make a better large station
Bartsimho
17 Jan 2023
Chesterfield
Which Bradford? Assume you mean Forster Square, which was not planned as a through station; it was to be the point at which the Midland would run a new line to from north-east of Low Moor, bypassing Exchange (now Interchange).
A complete line in a tunnel with underground main line platforms: https://www.bradfordhistorical.org.uk/allchange.html#:~:text=1894-1919: West Riding Lines and Bradford Through Lines Acts
WW1 killed it with rising inflation post-war and then the amalgamation of the Midland Railway into the London, Midland and Scottish railway controlling the WCML
Wolfie
17 Aug 2010
Maybe they're a little far apart to create a single station, but I used to live in Leytonstone and thought that properly connecting the High Road station with the Underground station would have been a good idea. If you build south from the station car park there's plenty of room beyond the cess on the western flank to provide quite wide footpath. You could fairly easily shift the High Road station towards the A12 as the remnants of the originals platforms are still extant and could be refurbished.
The, ahem, Elephant in the room for London though is that one near the big roundabout that used to have a great shopping centre on top of it. Can't think of the name right now but I'm sure you know the one I mean ;). Connecting there is terrible, once you exit the Thameslink station you're on your own in the Wilds of Lambeth.
Well, except that the Elephant is actually in the London Borough of Southwark....
The Ham
6 Jul 2012
Farnborough Main and Farnborough North could do with direct interchanges, though that would move it away from the town centre.
While on that thought, moving Farnborough North a couple of hundred metres north to adjacent Farnborough Gate and providing a walkway between there and Frimley might be more plausible...
Something which would shorten the walk distance (and definitely the perception of how close the two stations are) would be to build a second access to Farnborough Main from the A325 to the London bound platform.
The obvious problem with that would it would be a second gate line to manage.
The walk to the Basingstoke platform probably wouldn't be all that much shorter.
LUYMun
15 Jul 2018
Cancelled
That was first suggested a while ago, with additional bus stops right outside that entrance, but I believe the narrow width of the A325 road bridge made it infeasible, alongside needing the relocation of the Up signal gantry.
Meerkat
14 Jul 2018
Why do you think an elevated walkway wouldn't get approved? Opposition from locals?
It would overlook residential property.
It would also be massive overkill - the walk between the stations is pretty direct and has the security of all the passing traffic. Deepdene desperately needs an upgrade though.
AlastairFraser
12 Aug 2018
Ah ****e, thought it was commercial property between Dorking Main and Deepdene.
Deepdene still needs lifts though.
MarkyT
20 May 2012
Torbay
About 250m from entrance to entrance on street today, with one residential road (Lincoln Rd) to cross. Google Maps says 4 minutes on foot. I wouldn't hesitate to use it as an interchange if ever necessary for my journey needs, not likely living in Devon but you never know!
It's residential along the A24 London Rd part of the current roadside pavement route, then commercial along Station Approach. Agree on lifts, although maybe graded ramps zig-zagging up the embankment, supplementing the stairs might be an alternative option with lower capital and maintenance costs and greater resilience, although would add distance for those that need to use it.
Fawkes Cat
8 May 2017
Having just looked at Google Maps, this does seem to me to be a case where - as with many suggestions here - most of the benefit could be got for a fraction of the cost with decent signing. The walk is along the pavement of an 'A' road which is presumably busy - but the pavement is wide enough to be used as a cycleway as well, so it shouldn't feel too unsafe for a pedestrian. It's got street lights - maybe these could be augmented to give extra security at night. But extra signs at each end (to point to the other station) and maybe on-pavement signs (BR arrowhead with an arrow each way perhaps?) should surely be enough.
AlastairFraser
12 Aug 2018
Graded ramps would likely be too steep for wheelchair users still, and lifts would be better placed to distribute load across the narrow platforms, rather than cluster in one place. You could refurbish the staircase as a graded ramp alternative.
Meerkat
14 Jul 2018
keep the stairs and put lifts in pretty much off the pavement. I think you want to fiddle with the embankments as little as possible……
AlastairFraser
12 Aug 2018
Given NR's recent adventure with parapets/embankments in Oxfordshire, I'd say they wouldn't mind having a look at the internal condition...
D6130
12 Jan 2021
West Yorkshire/Tuscany
Coatbridge Central and Sunnyside? Unfortunately there is the small matter of a severely-underfunded and rapidly-decaying industrial and transport museum in the way.
Sweetjesus
15 Jun 2019
With Curzon Street coming soon, it would be nice if an underground pedestrian tunnel is built connecting New Street with Moor St/Curzon St. I'm not sure whether the underground structures under Bullring gets in the way or not.
The existing route is not really nice to walk, involves crossing 2 busy roads (with 3 traffic lights in total) if using Martin's Queensway or crossing 1 busy road and quite steep hike up to the Bull and then down if avoiding Martin's queensway. Making it a nice walkable route with visible signs isn't really going to change the fact they're not nice nor safe in dark.
