In fairness, the existence of Burscough Bridge station rather requires this - unless you're proposing having stations named Burscough Bridge and Burscough not-Bridge.
Don't get the idea of renaming Wolverton or Bletchley, you would soon have people moaning "why am I 4 miles away from where I thought I was going?"
Appropriate if St. James station reopens. Edit: already mentioned. What about light rail stations/stops - several Metrolink stops come to mind. Burton Road should perhaps be renamed Withington and Withington to Princess Road.James Street to Liverpool Waterfront
Mainly for tourism reasons
Copied off Piccadilly Circus in London though.
There is more than the airport there. Probably more people use it to go to the NEC.Birmingham International = Birmingham Airport
I would guess that most people going to the NEC know it's near the airport than vice versaThere is more than the airport there. Probably more people use it to go to the NEC.
I also feel like Stratford Int'l should change, but no idea to what.
Sorry, you'll need to explain further about Rushden. Following that logic, every station in the country would have to list any nearby town. It's not even as if Wellingborough station has a convenient bus link to Rushden.Caledonian Road & Barnsbury -> Barnsbury
Shoreditch High Street -> Shoreditch
Brondesbury -> Brondesbury Kilburn
Norwood Jun -> South Norwood Junction
Catford -> Catford Thameslink
Wellingborough -> Wellingborough for Rushden (like Alnmouth)
University -> Birmingham University (University is as descriptive as calling London Bridge "Bridge")
Staines -> Staines-upon-Thames (half serious)
West Drayton -> West Drayton & Yiewsley
Caledonian Road and Barnsbury is on Caledonian Road but not in Barnsbury!Caledonian Road & Barnsbury -> Barnsbury
There was only a three year gap between closing Shoreditch and opening Shoreditch High Street so it was necessary to make it clear that it was at a different location. I think that it would be reasonable to drop "High Street" from the name when the station becomes due for some redecoration.Caledonian Road and Barnsbury is on Caledonian Road but not in Barnsbury!
Shoreditch High Street was given it's name to distinguish it from the former East London line terminus station.
Catford station is not only served by Thameslink trains so your proposed renaming is misleading and could cause confusion.
Except that the cost of redoing maps etc is non-trivial.There was only a three year gap between closing Shoreditch and opening Shoreditch High Street so it was necessary to make it clear that it was at a different location. I think that it would be reasonable to drop "High Street" from the name when the station becomes due for some redecoration.
That's a good shout, it should be called Middlebrook.Horwich Parkway to either Middlebrook or Middlebrook Stadium, which is what I thought it would be called.
I'd call it St. Annes, most people do.St Anne's on the Sea should be St Anne's on Sea
Sounds horrible, I suppose you could call it after its original name Store Street.Manchester Piccadilly back to Manchester London Road, ...
That's an understatement, there is a 'Moss Side' station on the Blackpool South line.(Shame Victoria Park and Moss Side don't have stations, as they'd fit the "stations that sound nice but aren't" thing if they did! )
I dropped someone off near Moss Side Manchester about 1am on a Sunday morning in the 80s. As we approached the lights there were lads knocking about, he told me if the lights turn red keep going and if we stopped behind a car leave plenty of space so we can make a quick getaway!
The two Hammersmith stations and the two Edgware Road stations on the London Underground.
A long time ago I went out with a girl from Rusholme, I could write a book about that. Her house was an old Victorian terrace and the bathroom didn't have any windows!I've lived there on the Rusholme side and it wasn't bad, far less trouble than you got in the actual student areas. But it's hardly salubrious
Not quite accurate for Reading West as some of the streets off Oxford Road are quite pleasing. The exit towards Tilehurst Road gives access to some 'leafy' thoroughfares and is not far from Prospect Park.Reading West--->Reading Grotty Part
Reading---->Reading Nicer Part
Though the two Hammersmith stations are close you can't see one directly from the entrance of the other. First time I visited Hammersmith I ended up at the wrong one after a concert and couldn't work out why there were no trains back to where I'd come from.The two Hammersmith stations are directly opposite each other across the road. The walk between them is shorter than the walk between lines through the tunnels at many other Tube stations. So I think I'd leave those alone.
Edgware Road I would probably agree, they are not as near to each other.
I don't entirely get why Bank and Monument are named separately; one side of me would rename the whole thing to Bank-Monument.
You could call it "Tring Station" station as the area around the station is shown as that on Google Maps.How about Tring Station. It's at least a mile outside of Tring! Not sure what you'd call it though!
The 2 Hammersmith stations felt closer together before the District/Piccadilly station was redeveloped with that shopping centreThough the two Hammersmith stations are close you can't see one directly from the entrance of the other. First time I visited Hammersmith I ended up at the wrong one after a concert and couldn't work out why there were no trains back to where I'd come from.
