Stockport platform 3, the down fast platform, has been closed for most or all of the day, Friday 5th. August.
Problem appears to be a "points failure" which I think will be at the Stockport No. 2 end, the down end, because bay platform 3A is also showing up as blocked on Open Train Times maps etc.
https://www.nationalrail.co.uk/service_disruptions/302499.aspx says
Fast services from the Crewe line (Avanti (when running, for example https://www.realtimetrains.co.uk/service/gb-nr:G65094/2022-08-05/detailed#allox_id=0), Arriva Trains Wales) are generally using the Styal line and bypassing Stockport to cut down the number of trains required to use platform 4 at Stockport.A points failure at Stockport is causing disruption to journeys through the station.
Services may be cancelled, delayed by up to 15 minutes or diverted and not calling at Stockport.
We anticipate disruption will continue until the end of the day.
