Stopped for ages, engines still running
MrCub
23 May 2009
SE England
I've just had the 'pleasure' of a trip to Kettering and back on a dismal 222.
While waiting for the return, I noticed that the service from London waits at Kettering before going to Corby for half an hour - this happens all day, albeit in the opposite direction during the evening peak.
The whole time, this five coach train was sat there, engines running, belching out fumes. Surely it would make sense to turn the engines off and save on fuel for such periods of time. Or am I being daft and it is actually more economical to have it running. Is there another reason why they do this?
Mr Cub
NSEFAN
17 Jun 2007
Southampton
I would have thought that for climate control, it's better to leave it running. Also firing up an engine takes up a fair amount of energy, especially if it's cold.
Perhaps it also reduces the risk of failure. Once started, it's less likely to stall?
LondonLarry
20 Jul 2009
Wherever I lay my hat, that's my home
It's probably better to keep the engines running for fuel efficency and for the overall life of the engine. Voyagers can't have long periods with the engine switched off and need to be run every 8-12 hours to prevent damage to them.
GB
16 Nov 2008
Somewhere
With just a half hour turn around there is little point in shutting the engines down and as said above, shutting down and restarting engines also uses fuel as well as increasing the wear and tear. Then of course you have all the electrical systems that would soon drain the batteries unless a shore supply is attached.
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
You might find this helpful,
http://www.railforums.co.uk/showthread.php?p=411506
Its from another thread in this section just a few days ago:
. . . . . pre-heat the diesel engine cooling water, ensuring that the diesel engines are never started from freezing cold, avoiding the shock and potential damage that this causes (this has always been and continues to be a problem for Valentas, as GC has found - MTU invalidates the warranty on its engines unless the cooling water is maintained at 40 degrees C or more).
If the warranty on your engines won't even let their temp drop to 40 above winter air temp then who's going to dare risk switching them off?
devon_metro
11 Oct 2005
Nobody, hence why in depots they are hooked up to a shore supply, and where not available, one engine is left on providing train heat.
dk1
2 Oct 2009
East Anglia
Unless more than an hour we never turn off engines on units. Mainly due to during winter the heating/air-con will not keep passengers warm & if the next driver turns up late to the train, waiting to build up air may cause a late start.
TDK
19 Apr 2008
Crewe
Mr Cub
If you shut the engines down the train looses it's air so then the doors will be accessable on both sides of the train, maybe this is why it was left running
DaveNewcastle
21 Dec 2007
Job for the RAC or AA boys me thinks :)
Aww, what's wrong with a good ol' push-start? Rail vehicles are designed to roll easily aren't they?
Just shove for a bit and then wave to the driver (looking in the wing mirror) to slip it into gear!
Hmmm. Maybe not. (But, have you noticed how train cabs in some countries really DO have wing-mirrors?)
Sir_Clagalot
9 Aug 2007
like this? Taken in Melbourne on the Epping Branch. One of my dad's cousins lives there (as does one of his sisters!) and her husband drives the suburban stuff from Epping. Managed to arrange a cab ride last time I was there<D Was great other than the 4am start!
