Heathrow Express - half hourly service, for Airport staff ONLY towards Heathrow
How is/was this being enforced?
That's railway - must be Hayes ATS. There is a distribution substation (bulk supply point) by the bend in Blyth Road, but all the stuff is kept indoors. It's one of four BSPs fed from the grid at North Hyde; two are collocated with North Hyde GSP and one is further away at Vicarage Farm Road.Isn't there some electrical switchgear at the end of Keith Road in Hayes, just by Dawley Road bridge?
There's only been one fire. If that causes knock-on issues that shut the whole airport down then, regardless of what other arrangements might be in place, that is a single point of failure.It doesn't. Multiple systems at multiple places must have failed to totally shut the airport down like this.
It’s probably worth mentioning that the airport is supplied and managed by UK Power Networks who act as an independent Distribution Network Operator (iDNO) for the entire site. Depending on where the point of connection is, it’s entirely possible that this supply is UKPN from the 66kV compound at North Hyde.This, according to SSEN (the distribution operator), is the "illustrative" supply area of the North Hyde grid supply point. It does not include that much of the airport: only T3 of the terminals, though there may be important central services in there. But I'm not sure it should be taken that literally, in the absence of any knowledge of the boundary between SSEN and HAL in terms of providing power circuits within the airport. That "illustrative" must cover up something.
It was a FS initially, supplied by a buried cable, now re-purposed.That's railway - must be Hayes ATS. There is a distribution substation (bulk supply point) by the bend in Blyth Road, but all the stuff is kept indoors. It's one of four BSPs fed from the grid at North Hyde; two are collocated with North Hyde GSP and one is further away at Vicarage Farm Road.
I think there are at least 10 main DNO feeds into the airport from 4 bulk supply points. The newer feeds from the other supply points are 33kV, but two (including the one that when pop) are older 22kV ones.This, according to SSEN (the distribution operator), is the "illustrative" supply area of the North Hyde grid supply point. It does not include that much of the airport: only T3 of the terminals, though there may be important central services in there. But I'm not sure it should be taken that literally, in the absence of any knowledge of the boundary between SSEN and HAL in terms of providing power circuits within the airport. That "illustrative" must cover up something.
I never said there was more than one fire...There's only been one fire. If that causes knock-on issues that shut the whole airport down then, regardless of what other arrangements might be in place, that is a single point of failure.
Electricity is the easiest service to design alternative supply routes for. Gas and water are far more challenging.
No extra services from Brussels, but I was on the last train of the day from Amsterdam/Brussels to London, and it definitely had diverted air passengers on it. I think it would otherwise have been fairly empty, so was able to take up a bit of the slack.Eurostar will now run two additional trains each way between London and Paris.
Fermeture de l'aéroport d'Heathrow: Eurostar ajoute des TGV entre Paris et Londres
L'opérateur a décidé "d'ajouter de la capacité afin d'aider les voyageurs affectés par ces perturbations".www.bfmtv.com
Loss of grid supply is low probability but impact is massive which is why railway signalling systems have at least two independent source supplies and signalling centres/ROCs will supplement that with standby generators and 2-4hr UPS battery backed supplies to all safety critical systems. Heathrow isn't some regional airport its national critical infrastructure and should be able to deal with this scenario.In terms of supply from the grid at other places, Staines and Bedfont are fed from Laleham GSP and Longford from Iver GSP. So alternative feeds are present on the site.
The recovery process today has presumably involved making new connections from these alternatives to the loads now with no supply, manually and so slowly. And I can only conclude, from what HAL have said, that the answer to everyone's question - why did this take about ten hours rather than ten minutes - is "this behaviour is by design". HAL's commercial decision was that the loss of a grid power feed had such a low probability that the cost of rapid (not necessarily automatic) changeover switching was not justified.
Most likely making the 'spares' work the additional trains but the resilence would have been lost if someone phoned in 'sick' at the last minute.Not exactly a lot of additional capacity but you know what fair play to them for scrouging something together at very very short notice. It can't have been that easy to cobble together an additional crew and unit without also risking leaving their normal service uncovered.
Or that introducing such switching added an extra point of failure that had a bigger probability of causing disruption than losing the grid feed.In terms of supply from the grid at other places, Staines and Bedfont are fed from Laleham GSP and Longford from Iver GSP. So alternative feeds are present on the site.
I once squished a proposal to add an additional layer of reslience to the company intranet service. All I did was ask for the with and without expected reliability for the whole service. The proposer was free to make their case, never heard any more.Or that introducing such switching added an extra point of failure that had a bigger probability of causing disruption than losing the grid feed.
Well it sounds as though the extra switching paths were already present, so any additional risk already baked in.Or that introducing such switching added an extra point of failure that had a bigger probability of causing disruption than losing the grid feed.
If there’s no power then the DOO cameras would have been offline. The drivers would lock out the rear 4/5 carriages and self dispatch the front.On the Friday morning, Hayes & Harlington station had lost some/all power, but it was open, and trains were calling there. Eastbound trains could not open the doors in the rear 4/5 carriages. Does anyone know why this would have been?
That’s correct, this also affected platforms 1/2 (Down & Up Mains) and platform 3 (Down Relief). A diesel generator was brought to site later in the day, which once setup allowed normal working to resume without doors being inhibited.If there’s no power then the DOO cameras would have been offline. The drivers would lock out the rear 4/5 carriages and self dispatch the front.
How do they go about doing that on the Lizzie? Are there some secret hidden internal barriers/doors that can be deployed to prevent internal access to carriages or would this be handled solely by announcements that SDO is in operation and certain doors won't open?The drivers would lock out the rear 4/5 carriages
Although FWIW, not that it’s relavent here but for the benefit of the person asking the question, there are smoke doors half way down the train, not sure if these are capable of being physically locked closed.It's done from the driver's cab prior to arrival at the station - it's effectively an SDO setting to inhibit the rear half of the train. There's no internal access prevented, just external doors won't open.
That would have been fun for any pax wishing to alight from those carriages!It's done from the driver's cab prior to arrival at the station - it's effectively an SDO setting to inhibit the rear half of the train. There's no internal access prevented, just external doors won't open.
It's not uncommon - I've encountered it a couple of times when the cameras haven't been operational at a certain station.That would have been fun for any pax wishing to alight from those carriages!
