gg1
One of the most commonly suggested line re-openings is the Sutton Park line, but where I think it falls down is at the eastern end where there are generally 3 suggestions, Water Orton/Coleshill which both have a limited potential market and connection opportunities, or New Street, which would be a very indirect route for most potential stations on the line.
My idea is to build a new line from Water Orton to Berkswell, running parallel to HS2 with it's own platforms at B'ham Interchange, then running a half hourly service from Wolverhampton>Walsall>Coventry.
The benefits are:
New local rail travel options between settlements/suburbs on the route itself
Coventry to HS2 - if XC is restructured post HS2, there's a very real chance Coventry could lose it's direct services to the north. This would compensate to a greater degree than a slower, less attractive connection between International and Interchange.
Much quicker journeys between Sutton Coldfield/Walsall (plus the chase line settlements) to both HS2 and classic lines to points south of Coventry than by changing at New Street/Curzon Street.
Freight services which currently traverse the Stetchford-Aston line could be re-routed along this route freeing up a little capacity between New Street and International.
What are peoples thoughts?
The benefits are:
