SWR Class 458 to be retained
RealTrains07
28 Feb 2019
At the time the 458 and 460s were converted to 458/5s
Didnt SWT plan for them to work together with the 450s? Isnt that why they have a cab gangway in the first place?
They had a better gangway than the original fitted for multiple working within their own class, and the couplings were changed to allow rescue coupling only by Desiros. Never intended to work together.
(The original 458 gangway was only joined or split within the depot. The 12 ex-460 driving vehicles got gangways for the first time.)
30 Jul 2015
Be interesting to see if use of the gangway doors is resurrected? Biggest pain at the moment is to find that you are in the half of the train that has no working toilets and you can't get to the other unit.
Goldfish62
14 Feb 2010
Suburban 2+2 is wide aisles and no tables, unsuitable for mainline work. Presumably it'll be an upgrade to Class 444 type interior.
The actual spacing of the seats is already there due to the large seat spacers used. The gangways aren't really any wider than in a mainline 2+2 carriage. They just need armrests.
Dan15812
18 Oct 2018
SW
I wonder if they'll get their vinyl replaced with carpet? That will be interesting!
Thought they were using them on those units.
When they're a considerable upgrade from 3+2 seated 450s I'm not sure how important armrests would be. Tables would be useful though.
I do indeed wonder as some have if they'll put the seats and tables from the 442s in, though, as those already have armrests.
Aren’t the 458s restricted to 90mph, so not going to be useful on fasts or semi-fast on the main Winchester line.
But I guess the lower gearing might help on the twisty and less flat Portsmouth direct line. However might be sensible to keep them on self contained diagrams, something like Solent lines
CBlue
30 Mar 2020
East Angular
75mph currently. As a post above stated, they're getting regeared to 100mph again
theironroad
21 Nov 2014
It would be good if they could utilise the carpet from the 442s somehow, provided by Axminster iirc.
Imagine they could find a way of stitching bits together where required.
Matt Taylor
31 Aug 2008
Portsmouth
Another advantage of the 458s is that they don't require a shunter to couple them up so it opens the possibility of them going on the Weymouths.
Dan15812
18 Oct 2018
SW
I've nether understood the difference in window panelling on 458's! Would be nice if they could all get consistent window frames fitted! :lol:
It would be nice if the toilets got upgraded for their new role. They didn't work the first time they were reprieved at the expense of the 442s.
They can do that by just binning the cars from the 460s.
This is because they're a mix of coaches from 458s and 460s, the former had gasket glazing and the latter had glued-in ribbon glazing, and it presumably wasn't worth the cost of changing it.
Goldfish62
14 Feb 2010
Agreed, and they were completely untouched by the five-car project.
David Goddard
8 Aug 2011
Reading
That would be quite an expensive project for what is effectively vanity.
Not if they want to retain 36 sets. Seriously why not return 1-30 to original 4 car formation then make the others (made up of the old 460 vehicles) up to six x 10 car trains, possibly for dedicated diagrams. Understand this is part logic, part OCD but saves losing vehicles which are only twenty or so years old so only at half life.
pompeyfan
24 Jan 2012
There’s already quite a bit of concern they’ll be converted to DOO but I don’t know if there’s room in the cabs for monitors.
David Goddard
8 Aug 2011
Reading
Four driving cars already scrapped during the conversion process.
Oh yes, realise that, have photos of them at Doncaster awaiting disposal. make that "saves losing any more vehicles which are only twenty or so years old so only at half life"
Is it even likely? Seems to me they’ll be operating mainly on the same or similar routes as 444 and 450, and neither have monitors...
Fincra5
6 Jun 2009
The cab looks small, but no more cramped than Electrostars..
Looking at pictures, its more cramped than 377s (Picture)! Can't actually see where you'd even put DOO equipment given where the TMS is!
43096
23 Nov 2015
Why not? Because you're making yet another odd ball sub-fleet compared with 30 or 36 x 4-car units that can run at maximum 12-car length. And that's before you look at the make-up of the spare vehicles in terms of motors or trailers, TMS capabilities etc etc etc. Just a total non-starter.
Goldfish62
14 Feb 2010
Stagecoach specified them for DOO because they were intending to DOO all suburban services, hence they have door buttons on the drivers desk. No in-cab monitors because they were going to use platform mirrors and monitors.
Surely unlikely given the DOO equipment was removed on the 442s.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
I think the 350/2 would have been a better option than this, with a longer remaining life following conversion, so presumably Porterbrook still have them earmarked for something else?
My thoughts exactly, I would have rather have had those to be honest as it would at least have given SWR and Siemens a more standardised fleet.
So, with the 442s now going, it looks like Triggers Broom has had a replacement. The Juniper aka Triggers Broom Mk2.
It’s also somewhat ironic that, for the second time on the South Western, the 442 is being seen off by the Alstom Juniper fleet!
