Westcoaster: As a fellow driver I would never normally doubt your answers, especially as you know Brighton and I don't, but I'm afraid your answer doesn't quite stack up.
Firstly, I have yet to visit a terminus station where the platform lines have AWS for the platform starter signal. If the reason for these boards is due to the positioning of 3 car units, the problem is more likely to be down to the TPWS overspeed loops on approach to the buffer stops. As you know, these are always live. Positioning therefore becomes more critical because you will get a persistent TPWS fault if you attempt to liven-up the desk where the receiver is over a live set of loops. The only way to remedy this fault is to move the train. We have the same problem on P3 at Chingford, so the powers-that-be installed an "S Car Stop" board on one of the canopy supports so that the London-end cab didn't get parked on top of the TPWS loops. This being so, I don't understand why Southern didn't install a "3 Car Stop" board of the usual type either on a conveniently located post or screwed onto the sleepers.
The reason for my confusion is that "T3" is usually a reference to taking a line under possession for engineering works.
O L Leigh
