DaveHarries
Hi all,
I think I am posting this in the right place.
I am trying to put together a SimSig timetable for Sunday 08th May based around quite a few engineering works. I so far have 200 trains written in but I am a bit stuck with a couple of things relating to the Tattenham Corner & Caterham services on the day in question. Therefore it would be appreciated if somebody could help me on these two points so I know how to set things up.
1. On the day in question the Caterham services, which would normally operate to / from London Bridge, are revised to run between Caterham and Tulse Hill only. I believe that the normal unit allocation would be 5/377 (ie. 5-car Class 377) but seeing as the trains will be running short is this likely to still be the case? I guess the Tattenham Corner - Purley services will also remain as 5/377.
2. It is impossible to deduce on RealTImeTrains how the 0758 Purley - Tattenham Corner gets to its start point as there appears to be no passenger or ECS working for it on RTT. To that end I would be tempted to assume that 2Z09 and 2P09 share the same platform with one dropping the unit for the other. On that link though they are shown as using different platforms. Does anyone know whether 2Z09 will drop the unit for 2P09?
RealTimeTrains link to Purley for 08th May: https://www.realtimetrains.co.uk/se...22-05-08/0000-2359?stp=WVS&show=all&order=wtt
Thanks for any help on this.
Dave
Dave
