Yep did 2 test with the second one your not meant to finish it, it’s a way to put pressure on you to try and make you rush and make mistakes, it’s quality not quantity with these tests. Obviously at the end the higher scores will get put through, good luck
Strange as I only had one test...least and most likely answer one! I didn't get the other test.
