Track gradients around Sutton
Bayum
21 Mar 2008
Just been watching some videos of trains at Sutton. It appears there are some quite steep gradients on the line via Wimbledon and one of the lines coming up to Sutton. How steep are these please?
DelW
15 Jan 2015
Well, I think that the line between Sutton and West Sutton was nicknamed the "Wall of Death", but that may have been for its curvature rather than its steepness.
Magdalia
1 Jan 2022
The Fens
West Sutton to Sutton is indeed the Wall of Death.
The climb is steep from Hackbridge through Carshalton up to Sutton too. That's table S7 in the old Ian Allan Gradient Profiles book and is 1/96 then 1/86.
Try here:
Thanks for this link. However, looking at the Wimbledon to Sutton gradient profile, I doubt that the vertical scale is correct. I think Sutton is a lot more than 4 metres higher than Wimbledon. That's less than the height of a 2 storey house!
Sutton and nearby Epsom are close to the Epsom racecourse. As it happens the Epsom Derby is next weekend. Watch it on TV to see what the North Downs are like. If you are lucky they might show a gradient profile of the course that the horses have to run.
By quickly looking at an old large scale OS map with regular spot heights, there’s an 80ft to 210ft height difference between the roads outside the station entrances, say 40m. Maybe there’s been a decimal point error somewhere in the conversion…
thedbdiboy
10 Sep 2011
It was indeed the gradients that earned the nickname
Peter Mugridge
8 Apr 2010
Epsom
It was earned in first generation electric unit days; in leaf fall season they would often slip to a halt while coming up the gradient and it would be common practice to wait at the second signal for a clear run to ensure they wouldn't get held at the one just short of Sutton at the top of the gradient.
rower40
1 Jan 2008
Lightweights...
Bodmin Parkway to Bodmin General has a ruling gradient of 1:37.
Basil Jet
23 Apr 2022
Really? A "Wall Of Death" is a hollow cylinder with a curved bottom so that motorcycles can ride around inside the bottom and speed up and gradually climb up onto the inner vertical surface, most impressively if there are two motorbikes going around at the same time 180 degrees apart. I imagine that the curvature was a crucial part of why this railway got the nickname.
Tester
5 Jul 2020
Watford
Agreed - and if my memory serves me correctly, at the Sutton end there is an impressive section of vertical brick 'cutting' on curves.
Rescars
25 May 2021
And a popular fairground spectacle at the time the St Heller loop was constructed.
