hi there....just sifting through this thread and hoping to pick your brains as have these tests next week and beginning to stress....
Are the memory test pictures 'busy'? what I mean by that is is there loads of things to look at and take in? Do they come up for a second or two seconds? are all the items in focus?
Ref the 2Hand, are all the shapes curved in shape? Or box like? reason I ask is that it would be quite tricky moving a ball around a curved shape? Is it ok to go out the lines? How many times would you get away with this? I take it its important to be rapid?
Is there a WCT test? I got the practice pack with this in it but see much about this on here or anywhere else?
MMI? Im glad to hear that the woman was encouraging, this worries me the most. Is it acceptable to use all examples from the work place? or is it wise to use personal life? or do you think it even matters?
Any tips would be great... thanks
The ATAVT - the images lasts up to a sec and some of them are busy and some less busy, you get a good mixutre. I dont think everyone goes through the same images. Think they will a good bunch and candidates gets random ones out of the bunch. you can take enough time in between images for your answer and to focus again before the next image.
2Hand - both straight box sections and curved sections as well. Same shape 10 times however you do get to practice the same shape twice before you start the actual test. Key is "speed and accuracy", this is repeated a lot during the day. you hear a tone through your headphones when you go out of the track.
No WCT for us on our day.
![Smile :) :)](/styles/default/xenforo/smilies/rfsmile/smile.gif)
MMI - was told you could use all examples from work and thats fine.
Be prepared but no point in stressing out. Use that energy positively for mind and thoughts. Good luck
