Transpennine Route Upgrade and Electrification updates
Full electrification is looking inevitable - the benefits of four tracking are only fully realisable if there's a switch to higher performance electric rolling stock which will give the desired acceleration and headway performance being sought. Four tracking, on its own, risks slowing down services as additional station calls can be (re)introduced, particularly if they are slow accelerating diesel units.
And presumably similar arguments can be made for the section between Neville Hill and Church Fenton. Faster accelerating EMUs will help ease the capacity crunch on that section. The argument is perhaps not as strong as that for Huddersfield - Leeds but still, should be enough to tip the balance you'd have thought?
However for Neville Hill to Church Fenton the "four tracking" could be use of a bit of HS2/NPR infrastructure.
AndyB28
8 Sep 2018
Just to add to Jonesy3001's photo, there's now an information board on the small traffic island just out of shot to the left. This suggests that there will be two, extended closures of Queens Road between May and August next year. I would assume this will be for the installation of the new bridges.
jonesy3001
13 Jul 2009
Otley, West Yorkshire
This is the sign, I work not far away from the compound, seen to be doing something to the oldham rd bridges as well, but only happens during the day.
anorack 1
18 Nov 2015
NR have built a big compound in Miles Platting for the improvement of the Manchester Stalybridge section. I presume this will include elecrification.
Has electrification from Victoria to Stalybridge (or anywhere further east) been authorised and funded? If not, the compound won’t be for any electrification. If it has, then I’ve missed the announcement (which would surely be big news)
a_c_skinner
21 Jun 2013
(With apologies for simply always saying the same thing.)
How on earth does any sensible planning leave us in this mess? The way we look at value for money must be wrong if it can leave gaps in the main route and obvious less main routes (like the Leeds to Hambleton Jn) unelectrified. This is like the algorithm for A levels, it has logic but patently has come out with the wrong answer. Likewise stopping wires at Selby, that vast sprawling metropolis where the bulk of journeys start and end. It may have made sense by the cock-eyed logic of Whitehall but in the real world anyone with the brains of a gnat would have asked why?
I know this sounds like a rant, it isn't, I really cannot understand the logic applied that gets these suggestions from the centre.
Well, Neville Hill to Hambleton was a decision taken by BR in 1984; electrifying the gap may seem obvious to you, but it clearly didn’t to the various engineers and operators involved back then.
Railwaysceptic
6 Nov 2017
1984 was a long time ago. Innumerable surveys and studies have been carried out since then and even a few decisions have been made.
takno
Selby is the first place you come to where you can reasonably do a locomotive swap. Obviously we don't do those now because a certain civil servant believed they couldn't be done in less than 3 hours and required the sacrifice of a goat, but back in the 80s they were still considered a practical way of switching modes on long distance trains
IanXC
Emeritus Moderator
18 Dec 2009
I always had the impression that Selby was based on the old timetable which had an easy of Leeds stopper terminating there every hour. If you were going to Hambleton anyway Selby really isn't much further at all.
Of course now that that service goes to Hull you'd have to alter the timetable to get the same benefit but that's not unheard of.
Indeed so, although I think it was GNER. But one (or even two) proposal(s) doesn’t make ‘inummerable studies and surveys’. I’m not sure there have been *any* surveys.
Railwaysceptic
6 Nov 2017
Really? About Leeds- Hambleton?
You've misunderstood my point. Since 1984 the railway industry has looked again and again at various possible projects, Manchester to Leeds being a prominent example. Why has no-one re-examined the merits of electrifying Hambleton Junction to Leeds? A decision made 36 years ago should not be the last word on the subject.
Mollman
21 Sep 2016
Except Selby - Leeds was part of the pre-Graylingised plan for TP-Electrification.
I recall that, around 15 years prior, they also tabled a bypass HS line along parts of the ECML, dubbing it a "VGV", in addition to wiring Leeds - Hambleton. Obviously neither got beyond the proposal stage!
I think Leeds-Hambleton was GNER and Virgin proposed the high speed line, complete with gauge-inappropriate graphic of TGVs in Waverley. I guess Virgin might have thrown in Leeds-Hambleton too, as it would have been small change in that project.
a_c_skinner
21 Jun 2013
GNER proposed KGX to KGX via Leeds with (IIRC) the NH to Hambleton referred to as the Electric Horseshoe didn't they? It improved stock and platform utilisation at Leeds.
Found it. I'd quote it but is all off topic!
Ianno87
3 May 2015
Until bi-mode trains came along, what trains would have actually been able to use it without also electrifying something substantial somewhere else too?
Although it demanded an extra path in the busy Leeds-Micklefield Jn route (and would have restricted Wakefield to 1tph)
