Transpennine Route Upgrade and Electrification updates
twin turbo
12 Oct 2019
Progress update on the East side - now with bullet points.
TransPennine Wiring East Progressometer Post 7.0 - accurate to 18/06/21.
Route announced as 'to be wired' in CP6: Church Fenton - Colton Jct.
E1. Church Fenton North Jct (NOC/CFM 10m 36ch) to Colton Jct (NOC 5m 41ch/ECM4 182m 79ch)
Electrification work underway.
Southern limit of OLE confirmed to be short of Church Fenton Stn itself due to
a) HS2 Phase 2b works; and
b) the Common Ln Underbridge/Rose Lane UWC situation (i.e. "Steventon with S&C")
With completion scheduled for October 2022; steelwork up in May 2021 (Normanton side only) & wires up in Jan 2022.
Leeds side steelwork originally planned for Autumn 2021, but work has been brought forward.
Colton Jn - Colton Lane O/B:
  • 3 S1 TTC pairs up, followed by a S1 Monoboom, a UKMS Std portal, another S1 TTC pair, a second Monoboom, then 4 TTC pairs to Colton Lane O/B over both the Leeds & Normanton Lines. The monobooms likely signify an overlap.
  • Over the Normanton lines, all 4 TTCs south of the overlap are Series 1 (two NOC/09/XX structures, then NOC/10/01 and NOC/10/04); the TTCs over the Leeds lines include a UKMS Std TTC (structure no. NOC/10/02) which also appears to cover the DL/UL crossover. The other 3 Leeds lines' TTCs (two NOC/09/XX plus NOC/10/02) are Series 1.
  • On the Normanton side, mast brackets for the cantilevers are now starting to appear - these will be of the Siemens "SICAT SA" type seen at Stevenage P5 & Paisley Gilmour Street - Gourock. The brackets are going up on the mast legs for the Up Normanton, and on stovepipes (where fitted). Earth Wire brackets are also appearing now.
Colton Lane O/B - Brumber Hill O/B (i.e. Colton South Ladder)
  • All steelwork aside from one monoboom (the UN leg of which is now up) appears to have been installed between Colton Ln & Brumber Hill (i.e. over Colton South Ladder); the TTCs are all Series 1 except for one over the Leeds lines (NOC/10/08) and one over the Normanton lines (NOC/10/xx).
  • Another structure on the Normanton side (perhaps NOC/10/11) has been fitted with a 'tongue' for a strut tie, and mounting brackets for Tensorex units facing towards Normanton/Leeds; its twin on the Leeds side (NOC/10/12?) has them too, but facing towards York. This makes me think that Colton Sth Ladder might be tangentially wired rather than with a traditional "cross contact" arrangement. Additionally, NOC/10/11's tie pile has no base plate, whereas NOC/10/12's does.
  • Immediately north of Brumber Hill O/B, a UKMS 'vierendeel' portal (similar to those used on the GWML in the 1990s) has been installed, possibly for MPA use.
Brumber Hill O/B - Bolton Percy O/B (Oxton Lane?):
  • South of Brumber Hill Bridge, almost all S1 TTCs appear to be up and boomed as far as signals Y745 (DL)/Y746 (UL)/Y747 (DN)/Y748 (UN).
  • S1 monoboom NOC/11/03 now has in-running stovepipes over all 4 lines, and brackets have been installed on those over the DN & UN. Its overlap compadre (NOC/11/08), 3 spans south, is now fully boomed, but the strut on the Leeds side is still outstanding.
  • South of that overlap are 7 S1 TTC pairs, followed by a UKMS Std PF DC portal (at a guess) for a mid-point anchor (MPA). A further 2 pairs of S1 TTCs are up south of that, along with two additional S1 TTCs on the Leeds side (NOC/12/02 & NOC/12/04).
  • NOC/12/02 & NOC/12/04's twins on the Normanton side of the line (NOC/12/01 & NOC/12/03) await installation; as far as I can make out, 12/01 is another S1 TTC, while 12/03 is a UKMS Std TTC.
  • A handful of masts (UKMS standard I think) are up between the Normanton lines on the old site of Bolton Percy station; those adjacent to the Up Normanton (NOC/12/05?; NOC/12/08; possibly NOC/12/11) are taller to allow increased Earth Wire heights over the RRAP at Bolton Percy. EW clamps have already been attached.
  • The masts for the Dn Normanton (NOC/12/06; NOC/12/09; NOC/12/12) are shorter as they have no earth wire and will be bonded directly to the traction return rail. NOC/12/06 also has a back-tie pile north-east of it.
    The corresponding masts for the Leeds lines are S1 TTCs (NOC/12/07; NOC/12/10; NOC/12/13). Another mast (NOC/12/14) is in next to the bridge, and will support OLE over the Up Normanton.
Bolton Percy O/B (Oxton Lane?) - Ulleskelf:
  • Between Bolton Percy & Ulleskelf, around 7 S1 TTCs, 5 S1 single track masts and a monoboom (now boomed) are up.
  • Two UKMS Twin Cantilever masts (pre-fab double channels/PF DCs) are in next to the Normanton lines south of Oxton Ln; these are NOC/12/19 & NOC/12/20. A further two are up behind them; these are NOC/12/22 & NOC/12/23.
  • On the Normanton Lines, south of signals Y741 (DL)/CF742 (UL)/Y743 (DN)/CF744 (UN) and north of the bridge over the River Wharfe (NOC/17N), 4 S1 TTCs have gone up (with booms).
  • North of New Rd (B1223) O/B, 3 piles between the Dn & Up Normanton lines are also in place, and clearances from the railway boundary to the Dn Leeds line are tight, so I suspect 3-track TTCs will go in over the Dn Normanton & both Leeds lines (unless more piles for the Leeds lines come later). 3 more piles are up in the Up Normanton Cess, and bear 3 STC masts (NOC/14/01, NOC/14/03 & NOC/14/05)
  • Within Ulleskelf itself, 3 single track masts are also in place for the Up Normanton (one between the road bridge & the footbridge, one just north of the 'Wernick Hire' welfare units (possibly NOC/14/13?), and one opposite the green Murphy containers), and a pair south of the station that are very tall indeed (perhaps to give aerial clearance over the RRAP which they sandwich).
  • A UKMS legacy TTC (from the Mk3 & Series 2 ranges) is also present south of Ulleskelf station; this gives adequate signal sighting over signal CF 738 (UN). There is also, in the 6-foot between the DN & UN, a mast for a UKMS Std Portal (probably another MPA).
Ulleskelf - Church Fenton North Jn (Limit of Wiring):
  • Between Ulleskelf & CF North Jn, around 20 or so masts (mainly S1 TTCs) are up on the Up Normanton side. Oddly enough, a standard UKMS mast (either a PF double channel or a UC - it's hard to tell from a telephoto shot) is up north of the current CF726/CF724 gantry. It is assumed that all the masts for this have now gone up, as photos of progress are thin on the ground!
  • At Church Fenton North Jn, 4 masts have gone up south of the signal gantry supporting signals CF726 (UN) & CF724 (UL); these are 2 no. Tensorex Monoboom Anchor masts sandwiching 2 pairs of S1 style hook-and-pin TTC masts. This must be for an overlap - potentially the southern limit of works. Both overlap monobooms have been fully masted & boomed.
Track Sectioning Cabin to be built in Church Fenton.
Compounds established at:
Church Fenton;
Ulleskelf;
Bolton Percy (Oxton Lane);
Braegate Lane;
Earfit(ts) Lane;
Copmanthorpe (Moor Lane);
Tadcaster Road, Copmanthorpe (by A64); and Dringhouses (Model Railway).
(N.B. All dates are subject to alteration, whether due to COVID-19 or otherwise)
E2. Leeds Departures (presumed Leeds - Neville Hill - Cross Gates) - Development of final scheme scope to GRIP 3.
E3. Cross Gates to Micklefield - Development of final scheme scope to GRIP 3.
E4. Micklefield to Church Fenton - Development of final scheme scope to GRIP 3.
Landowners in the area of Rose Lane UWC (10m 79ch from York), Poulters UWC (11m 14ch) & Adamsons UWC (11m 36ch) have been notified of details to close the crossings and build a flyover & associated new highway.
Do let me know if I've missed anything!
Information coming out suggesting they are looking at lowering the track at Church Fenton as opposed to lifting the bridge which is causing them all sorts of headaches, this of course would be a lot less disruption to Church Fenton residents.
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
That would be far, far less disruptive to both the good people of CF & also the pax using the line, as track lowering takes noticeably less time to undertake than rebuilding or replacing a bridge, even though the lowering might have to be done in stages.
snowball
4 Mar 2013
The name Church Fenton suggests track lowering may present drainage problems. The OS map has a spot height of 8m in the centre of the village, and one of 9m on Common Lane to the west of the line.
YorkshireBear
23 Jul 2010
Not sure I would agree there. Track lowering and associated drainage and on this case platform lowering can be very possession intensive. Both likely as bad as each other from disruption perspective.
I despise track lowering as it inevitably leads to problems further down the line with drainage and track bed saturation as it puts in a low point. I accept it is sometimes the only way though.
hwl
5 Feb 2012
Would some bridge (e.g. to remove the extra buttress) work be needed for better track geometry and line speed for the fast services? (Or is this just being left for HS2 to fund later?)
twin turbo
12 Oct 2019
The integrated rail plan may shed more light on this when it gets released.
snowball
4 Mar 2013
Weekend closure for relaying at Ulleskelf:
Network Rail is upgrading the track between York and Church Fenton to bring smoother, more reliable journeys for passengers.
Between the last service on Friday 2 July and the first train on Monday 5 July, teams will lift around 450 metres of track on the busy line which runs through Ulleskelf station. Further upgrade work will mean changes to Northern’s Sunday service throughout July.
As well as making sure train services can continue running safely and reliably for years to come, replacing this section of track will reduce the amount of maintenance work and future disruption.
These upgrades will improve reliability in the area ahead of future improvements as part of the Transpennine Route Upgrade, which will bring more trains, faster journeys and a more reliable railway between Manchester and York via Huddersfield and Leeds.
For this work to be carried out safely, a section of the line will be closed. The following changes will be in place to keep passengers moving:
Saturday 3 and Sunday 4 July
  • Northern trains between Blackpool North and York will start/end at Leeds.
  • Northern services between Sheffield and York will start/end at Moorthorpe. Buses will connect passengers between Moorthorpe and York.
  • Buses will replace TransPennine Express services between Leeds and York.
  • CrossCountry services will be diverted and will not call at Wakefield Westgate or Leeds. Buses will run between Leeds and York. Passengers who need to travel to Wakefield Westgate should change at Sheffield.
Saturday 3 July
  • Northern services between Leeds and York will start/end at Micklefield. Buses will run between Micklefield and York.
Sunday 4 July
  • Trains between Leeds and York will be diverted and will start/end at Selby. Buses will connect passengers between Selby and York.
Sunday 11 July, Sunday 18 July, Sunday 25 July
  • Northern trains between Hull and York will be diverted via an alternative route between Selby and York and will not call at Sherburn-in-Elmet, Church Fenton and Ulleskelf.
There's also another press release about clearing fly-tipped rubbish at Heyrod.
59CosG95
18 Aug 2013
Digging around on the web for more compound information, I've discovered there's a compound at Garforth (east end of the stn; grid ref SE 409333), a compound at Micklefield (SE 427327 - though I can't find head nor tail of it on online maps) and a compound at Huddleston Grange (SE 474336). The latter two of these are offline and not well documented (I only discovered their existence through the ontrackplant forum).
Hope this is of use!
Ken H
11 Nov 2018
N Yorks
Gearing up for Neville Hill - Ch Fenton wiring?
Ploughman
15 Jan 2010
Near where the 3 ridings meet
Regards the compound at Garforth.
There has been an access point in place at Garforth Station, at the far Eastern end of the carpark, for many years.
I have used it between 1990 and 2009.
It may have been made more secure or convenient for works vehicles and material deliveries since then.
Isn't the station footbridge due to be replaced sometime? Listed structure I think.
Nicholas Lewis
9 Aug 2019
Item in DT tonight suggest treasury is deliberately delaying integrated rail plan
The Treasury was also accused of being behind the delayed publication of the Government’s integrated rail plan, which was initially due out by March. Northern leaders have repeatedly called for the urgent release of the strategy to give certainty around investment and delivery of the NPR scheme and High Speed 2 (HS2) in the north.
Suggestion is Leeds to Manchester new line (HS3) is to be culled in favour of existing route. If so full electrification has to be a must.
snowball
4 Mar 2013
This has been discussed in the Northern Powerhouse Rail thread. In the last 3 days there have been items in the Sunday Express, Yorkshire Post, Yorkshire Evening Post, Huffington Post and New Civil Engineer. But it's all still pretty unclear.
Here's one that I don't think has yet been linked on this site:
Johnson committed to delivering a key part of the £39bn Northern Powerhouse Rail (NPR) plan - a brand new line between Leeds and Manchester via Bradford - soon after becoming prime minister in July 2019.
Now, amid reports of wider Treasury demands to rein in Johnson spending pledges, sources told HuffPost UK of a “split” between the PM and No.11 over the plans.
It is believed that no decision on funding will be made until the government’s long-awaited integrated rail plan is published.
But three sources told HuffPost UK the Treasury is attempting to delay the publication of the plan to coincide with chancellor Rishi Sunak’s spending review in autumn, while No.10 wants it made public as soon as possible.
A source close to the discussions said they feared that delaying the decision until the spending review would mean “curtains” for a new NPR line, and possibly the eastern leg of the HS2 high-speed rail link to Leeds.
It was posted in the other thread yesterday, but you might have missed it:
snowball
4 Mar 2013
I now think I'd seen it there but was mistakenly thinking that it was one of the press reports I'd only seen on Skyscrapercity.
greyman42
14 Aug 2017
Which route are Cross Country taking from York to Sheffield during the Church Fenton- Ulleskelf upgrade?
59CosG95
18 Aug 2013
TransPennine Wiring East Progressometer Post 8.0 - accurate to 25/06/21.
b) the Common Ln Overbridge/Rose Lane UWC situation (i.e. "Steventon with S&C")
  • 3 S1 TTC pairs up (at a guess: NOC/09/07, NOC/09/09 & NOC/09/11 over the Normanton lines, with NOC/09/08, NOC/09/10 & NOC/09/12 over the Leeds lines), followed by a S1 Monoboom (NOC/09/13), a UKMS Std portal (NOC/09/14), another S1 TTC pair (NOC/09/15 & NOC/09/16 over the Normanton & Leeds lines respectively), a second Monoboom (NOC/09/17), then 4 TTC pairs to Colton Lane O/B over both the Leeds & Normanton Lines. The monobooms signify an overlap.
  • Over the Normanton lines, all 4 TTCs south of the overlap are Series 1 (NOC/09/18, NOC/09/20, NOC/10/01 and NOC/10/04); the TTCs over the Leeds lines include a UKMS Std TTC (structure no. NOC/10/02) which also appears to cover the DL/UL crossover. The other 3 Leeds lines' TTCs (NOC/09/19, NOC/09/21 plus NOC/10/03) are Series 1.
  • All steelwork aside from one monoboom (NOC/10/15; the struts & boom of which remain outstanding) appears to have been installed between Colton Ln & Brumber Hill (i.e. over Colton South Ladder); the TTCs are all Series 1 except for one over the Leeds lines (NOC/10/08) and one over the Normanton lines (NOC/10/xx).
  • Immediately south of bridge NOC-15 (Bolton Percy/Oxton Lane O/B)), there are two more structures presumed to have gone in; NOC/12/17 (probably a SSA mast for the Up Normanton) and NOC/12/18 (a monoboom for the other 3 tracks).
  • Two UKMS Twin Cantilever masts (pre-fab double channels/PF DCs) are in next to the Normanton lines south of Oxton Ln; these are NOC/12/19 & NOC/12/20. A further two are up behind them; these are NOC/12/22 & NOC/12/23. On NOC/12/19 & NOC/12/22 (both Up Normanton), the brackets for the overlap cantilevers are in place. NOC/12/19 & NOC/12/23 (Dn Normanton) also have EW brackets.
  • The two S1 TTCs opposite the Normanton Lines' pairs of Twin Cantilever masts (NOC/12/21 in line with 12/19 & 12/20; NOC 12/24 in line with 12/22 & 12/23) both have twin stovepipe assemblies for overlap cantilevers assembled for the Up Leeds line.
Church Fenton;
Ulleskelf;
Braegate Lane;
Earfit(ts) Lane;
Ken H
11 Nov 2018
N Yorks
Is there a post somewhere that tells me what a monoboom, stovepipe, etc mean. Or a link to an external source? Thanks
59CosG95
18 Aug 2013
Better yet, I can explain right here with my own picture.
The "monobooms" are the structures that look like this; they were initially used in a paired formation (i.e. two booms on one portal) on the GEML renewals programme (due to the large 'system height' (the gap between catenary & contact) of the OLE there). When these were deployed on the GWML, they only needed one, hence the 'monoboom' moniker. The 'stovepipes' are the square tubes fixed to the boom, which support cantilevers, earth wire/return conductor/Autotransformer wires, and various other OLE paraphernalia.
The circular stovepipes are only used with the monobooms, and support the 'Tensorex C+' tensioning devices which keep the OLE at the correct tension (the glorified Minky washing line drums).
Hope this all makes sense!
59CosG95
18 Aug 2013
Any recent photos of electrification to Church Fenton?
Flickr searches at 'brumber hill', 'colton', 'bolton percy', 'ulleskelf' & 'church fenton' should see you right. It's tricky to see progress at the last two as there haven't been many pics at Ulleskelf, nor are there many places to see the OLE north of Church Fenton as it's on the horizon.
Ken H
11 Nov 2018
N Yorks
thanks
nicolaboo
19 Jun 2018
The state of play at Miles Platting as of Sunday 27th.
td97
26 Jul 2017
Impressive footage of Miles Platting enabling work available at
This time-lapse video shows the erection of the 1000-tonne telescopic crane at the Queens Road Bridge reconstruction site in central Manchester. The three, 70 tonne filler beam precast concrete break deck units are delivered, lifted and placed, onto the two new abutments either side of the bridge. This represents the enabling works to the future partial demolition of the existing Queens Road Bridge and subsequent completion of the new Bridge and track alignment around Miles Platting curve during the 16-day closure in August 2021.
