Transpennine Route Upgrade and Electrification updates
hwl
5 Feb 2012
Which suggests TRU is being seen as meeting most of the Leeds - Manchester improvement wishes (it delivers more than half of the journey time reduction of new build NPR at far lower costs and improves both local and long distance journeys).
Beyond TRU scope the most obvious journey time reductions are in east Manchester with Piccadilly - Guide Bridge -Stalybridge being max 60mph with plenty of 50mph and several 25-40mph speed restrictions scattered along that section
Ken H
11 Nov 2018
N Yorks
And if they were to get their fingers out, they could deliver Manchester-York electrification in a few years. Long before any high speed solution would be delivered.
Buspilot
4 Feb 2012
So, if reversals are going to be necessary at Piccadilly, is there any need to remodel the western facing throat at Stalybridge Station, as it's good to go as is.
Reversals take place at Curzon Street only in the sense that they take place at any terminal station. The delay between arriving and departing is not part of any passenger's journey. At Piccadilly, in the scenario that now seems likely, the time for reversal and pathing delay would be part of every journey between London and Leeds. Even if HS2 NE goes ahead in full, the reversal would be part of every journey between Liverpool and Leeds.
Would anyone prefer a reversal (taking 5min or so) over the alternative of delaying any HS2/NPR service reaching Manchester by at least five years? It would take that long to design the through station and obtain all the powers, even if the funding was available.
Also, if there was a through station with a tunnel westwards towards Liverpool, it would probably surface as soon as possible and feed into an upgraded Chat Moss or CLC route instead of having (probably) high speed infrastructure at least as far as Warrington.
Starmill
18 May 2012
Bolton
Would a reversal in and of itself even be that much of a problem? Reversals will be taking place at Curzon Street, and everyone seems to accept that compromise.
Serving Leeds only via Manchester is much more of a problem than the minutiae of how those trains move within Manchester.
As snowball alludes to, in Birmingham, a new through station is being constructed. Trains won't need to reverse during their journey at Birmingham Curzon Street.
Starmill
18 May 2012
Bolton
I think that many reasonable arguments have been put forward for a terminal station, especially on cost grounds but also as you state on practicality and speed of construction. There is also the point that a better journey experience can be delivered in theory for trains originating there by having them waiting in the platform in advance of departure. But of course the background to the government's thinking is always cost and not any of this.
ABB125
23 Jul 2016
University of Birmingham
I don't think there's anything wrong with a reversal at Manchester. If at some point in the future it's determine that a through station is needed, then such a station can be built. See also Frankfurt,
Bristol
The HS2 website shows Cuzton St as a terminating station.
I think what was meant is that trains heading north of Birmingham will call at Birmingham Interchange Station, and only trains terminating in Birmingham will use Curzon Street. Therefore no train will reverse at Curzon Street as an intermediate stop en-route to it's final destination.
Starmill
18 May 2012
Bolton
There are of course some pretty critical things that it won't assist with, such as the constrained frequency from Dewsbury to Leeds and at intermediate stations, impractical and unreliable services from the four stations between Stalybridge and Huddersfield, relief on platform capacity Leeds especially with regards to the highly restricted platform 17, and of course the range of very poor speeds you mention. There is also the question of what infrastructure might actually be delivered for Liverpool-bound services... This is all for entry into service in the 2040s at some time.
This is correct thank you.
snowball
4 Mar 2013
That depends on how far NPR would be a new and separate route eastward from Piccadilly HS2 station, where the HS2 proposals now include stubs for a route to turn off just outside Piccadilly HS2. I imagine it would go at least far enough to bypass Stalybridge, even in any cut-down version.
I counted 60+ foundations between Bromley St and Ashton today, on both sides of the route.
East of the M60 there are just 3 on the north side, none on the south.
Most of the piles have square plates attached, maybe for TTC structures, the remainder have orange caps.
It's difficult to see what is happening in the cutting section west of Miles Platting, as the piles may be above the cutting walls.
Definite progress though.
snowball
4 Mar 2013
So maybe the piling progress site is not as out of date as I thought when it says 10% complete (it gives the total number of piles required as 543). But it also gives a completion date of this December, which does not seem very realistic now.
hwl
5 Feb 2012
Yes.
a) Capacity (3 tracks the western end / 3 through platforms)
b) Line speeds
c) Market Street Bridge at the East end.
The simplest solution for is to go for very long gantries which then allow the platforms to be reconfigured
WestRiding
21 Mar 2012
Yes.
b) Line speeds
Are they not going to electrify to Guidebridge too?
quantinghome
1 Jun 2013
Reversing through services at Piccadilly would be completely mad, especially if the plan was to run London-Leeds and Birmingham-Leeds services via Manchester as well as NPR.
Why? Through services reverse at various big city stations today, including Leeds, Birmingham New Street and Reading. It’s simply not a problem.
Ken H
11 Nov 2018
N Yorks
If you have a new driver/guard ready to take it out so there are no long walks for the crew. No reason you cant reverse in under 5 minutes
Glenn1969
22 Jan 2019
Halifax, Yorks
Because long distance passengers would have to suffer the same time penalty as Calder Valley passngers do at Bradford Int? Wouldn't it make HS2 London to Leeds slower than the ECML if all trains have to reverse at Piccadilly and obliterate the business case in the process? Plus the reversal for Sheff- Airport is said to be operationally challenging so surely having 200m trains doing it is stark raving bonkers if it can be avoided
quantinghome
1 Jun 2013
A tiny proportion of services reverse at those stations. Imagine if all the GWML services had to reverse at Reading, or all the TPE services had to reverse at Leeds. The implications on the throat design just don't bear thinking about.
Would they? Have you seen the modelled running times for services reversing at Piccadilly compared to those travelling via a tunnelled route?
Spoiler - I have.
There is no suggestion that all services would be reversing in service at Piccadilly High Speed either. Nevertheless, it really isn’t a problem.
quantinghome
1 Jun 2013
Spoiler - I have.
How many services per hour would be reversing at Picc if Leeds-London and Leeds-Birmingham get routed that way on top of NPR? Has any other new build main line station been planned along such lines?
The difference in running times between a reversing and a tunnelled route may not be a problem, but surely designing a throat big enough to handle all the conflicting moves would be?
It doesn’t need to be big.
That’s a big “if”.
Just as important as the configuration of Piccadilly (HS) is what happens after NPR traffic turns left at Ardwick.
If the 10 miles to Stalybridge stay as now it will defeat the whole "High Speed" objective.
A tunnelled route at least guarantees a reasonably fast exit from Manchester.
hwl
5 Feb 2012
Leeds - Curzon Street via Manchester is probably looking at a minimum 34 minute journey time reduction (vs currently, max 39@ best). Via HS2 east is 69minutes reduction. If you aren't starting at Curzon Street or central Leeds and need 1/2 interchanges then via Manchester may not end up being that attractive.
HS2b East's biggest issue is mess they have got is with what to do with Sheffield, which is probably due another cold hard think and review. With current costing elsewhere, having the main route tunnelled under Sheffield well below the three rivers with deep station box might turn out to be the cheapest (plenty of station under rivers in London).
Purple Orange
26 Dec 2019
The North
It doesn’t matter about the eastern branch times if it’s not built. What matters is the comparative journey time between the XC journey times via Sheffield & Derby vs journey times via Manchester. 35 mins will be enough to make people switch.
