Is it? As Grayling confirmed in his speech, the requirements for TPRU have driven to some degree by TfN/Rail North as opposed to the requirements for straight electrification which were derived from what Network Rail considered to be possble. If Huddersfield to Ravensthorpe is four tracked (and Ravensthorpe moved west or south), there would be only 4 stops on the two track stretch (Dewsbury, Batley, Morley and Cottingley) and stoppers even diesel could easily fit between 4tph expresses at 15min intervals. Under the planned May timetable the Northern skip-stop service and the TPE eastbound slowest service were due to (and probably still will) run between between Leeds and Heaton Lodge before being passed by expresses running every 15min. Four tracking beween Heaton Lodge and Ravensthorpe should allow the reinroduction of skipped stops.
Currently the stoppers just about keep out of the way of most TPEs, but looking at the timings between say Ravensthorpe & Leeds, TPEs get around 20 mins whereas stoppers get around 24-26 mins timetabled, meaning that the fasts are often not much faster than the stoppers on that section. Not exactly mind blowing for what 20-25% of the Leeds-Manchester route is it? And no matter how much padding is built in, it is not uncommon for TPEs to quickly run up behind stoppers even if the latter are running only a couple of minutes late, which can quickly turn into a queue.
With the skip-stoppers this might be relived a bit, but it's pretty useless for people wanting to transit between called stations & the skipped ones, and as often happens on other skip-stop routes like Liverpool-Warrington-Manchester, often the skip-stoppers when running late are sped up by missing calls, with the fasts behind having to pick up the slack. And that is on a route with just 2 fasts & 2 skip stoppers, the Leeds-Ravensthorpe section will have up to 4 fasts semi-fasts, 2 skip-stoppers and at least one Northern Leeds-Southport to shoehorn in. At the risk of doubting the planners, it isn't going to work great even as it is, let alone converting the skip-stoppers back to all shacks. Even with any additional track improvements that might be proposed to give better speeds, the slowest diagrams will always dictate just how quickly fast services can operate.
This is why I bang on about full electrification throughout, give the slowest services better acceleration away from stations & signals to get them further down the line before the fasts catch up. Maybe there will be little benefit in terms of timings because the route will always be hamstrung by being a largely 2 track route with a combination of fast / semi / stoppers, but electrification will maximise efficiency and lower the risk of delays, alterations and cancellations. I think the long term strategy is better than Grayling's ticking plaster solution.
