Why ?
If 37418 is based at Rhymney to rescue errant 769s there is a more than even chance it will be leaving the sidings at Rhymney to run downhill to the failure. So why not fit the coupler to the downhill end to do it's job. The rescue is required straight away, which is why it is required ASAP. Faffing around removing split pins, removing the shackle, then fitting the coupler just wastes precious time when the line is blocked and the customers are being buggered around.
surely when the loco is stood down to go for exam / service the shackle can be replaced just prior ?
Or am I missing something. In actual fact these things are just not delivering a satisfactory service, not even four units out of nine.
For answers to these questions please see my post in which you are replying to.
It takes minutes to fit the coupler including the grinding of the split pin. It would take longer to remove it and refit if it was fitted at the wrong end for the job than it takes to fit it as required, freeing up the loco to receive other couplers and duties as required.
I can assure you a full and proper independent review of the rescue process was made involving operations specialists and an independent safety consultancy and at no stage during HAZID or Ops review was any benefit observed as to prefitting a coupler.
This discussion is only being had because some veg saw a picture involving an angle grinder being used when fitting an emergency coupler for the first time. Of course, if one had operational experience in managing rolling stock rescue I suspect a different view would be had as to the normality and requirement of this procedure. I suppose that’s where I differ from all those talking about use of said angle grinder.
