Open top 80
Rochdale to Matlock Bath (460)
Huddersfield to Crich Tramway museum (901) on Summer Sundays and bank holidays during the 90s
Transpeak used to run Nottingham-Derby-Matlock-Bakewell-Buxton-Manchester. It was cut back to Derby, then withdrawn from Manchester to Buxton alongside the Northern timetable uplift in 2018. Today it runs Bakewell-Buxton with some journeys to Derby
All TPs seem to run Derby to Buxton, except the first and last on Mondays to Fridays, which run only as far as MatlockTranspeak used to run Nottingham-Derby-Matlock-Bakewell-Buxton-Manchester. It was cut back to Derby, then withdrawn from Manchester to Buxton alongside the Northern timetable uplift in 2018. Today it runs Bakewell-Buxton with some journeys to Derby
In the same era, there was a two-hourly 32 between Wigan and Manchester, which was timed with the 39 to provide an hourly service on the Atherton - Tyldesley - Manchester common part of the route. The vehicle arriving into Manchester (Greengate) on a 32 then departed as a 39, and vice versa.In 1977, there was a hourly 39 bus between Liverpool and Tyldesley with two hourly extensions to Manchester during Merseyside PTE and Greater Manchester PTE days
Similarly there are now no direct buses between Wigan and central Manchester. You need to change buses in Leigh or Atherton / Tyldesley for the Leigh Guided Busway, or take your chances with jams on the M60 and go via the Trafford Centre.Nowadays you have to change at St Helens and Leigh if you wanted to travel between Liverpool and Manchester.
At one time there was the L1 Chester to Caernarvon. Now multiple splits. Caernarvon to Llandudno, Llandudno to Rhyl, and the Rhyl Chester split as mentioned. In parallel to the L1 was the A1/A2 Caernarvon to Chester.Back in NBC days Crosville had the C84 between Chester and Newcastle U L later extended to Hanley. Now Stagecoach operate between Chester and Crewe as 84 and D and G operate a 85 between Nantwich and Newcastle via Crewe but it uses a different route between Nantwich and Crewe.
In Wales Crosville ran a Chester to Barmouth service now cut back to Wrexham and Chester to Rhyl services are now split at Holywell with Arriva. Others may be able to expand on those services.
The North West Road Car Company (NWRCC) used to run a large number of outdistrict services from several central Manchester termini/bus stations (Chorlton Street, Lower Mosley Street, Piccadilly and Stevenson Square), typically jointly with local municipal operators. Those few that survive have mostly been truncated to start in the ring of towns surrounding Manchester, and partly re-routed. Examples that I recall particularly include:Other long Crosville routes that spring to mind and are now split into shorter ones include:
E29/30 Manchester - Alderley - Macclesfield No longer possible to travel directly from Manchester City Centre to Macclesfield by one bus.
Thanks for that. I thought it had gone to Hereford at one stage as I was pretty sure I had used it to get to Hereford and meet up with some people, we were going to Brecon (pretty certain the fare was £2.97 issued as 3 99p tickets) but wasn't 100%. Maybe after Ludlow garage closed?The 192/X92 actually operated later on from Ludlow to Leominster and Hereford as well, replacing part of the 435 Shrewsbury - Ludlow - Hereford service.
They're withdrawn routes, though, which isn't what this thread asked for.Rochdale to Matlock Bath (460)
It was indeed A&D's 1, which ran from Aldershot to Egham. As part of the late 1970s MAP network revisions, the 201 route was totally revised to run from Basingstoke to Heathrow Airport. I'm unsure of the 201's history thereafter, but the "short route" variants of the 1 (by then the 202 and 203) eventually became Stagecoach South's Gold 1 route, reinstating the historic number in 1997. The 1 nowadays goes as far as the Old Dean estate (or Yateley prior 2003), which at first glance may seem to be the original A&D route, whereas it's not the case historically.That was before even my time. I remember it existing as the 200 (Basingstoke-Camberley only) but there was a separate 201 during the same era going from Basingstoke-Alton.
I wonder if the 70s version of the 201 (above) is some kind of descendant of the Aldershot and District 1, which was something like Aldershot-Egham and is shown in the 1969 Timetable World timetable? (No trace of anything like this exists now, nor did it even in the late NBC era in the 80s).
There was definitely a 37, operated variously by the "new" NWRCC or Warrington Transport, as late as the mid-to-late 90s, from Altrincham to Warrington only. Don't think there was a 36, but there was also a 38. One went via Dunham and the other went direct via the A56, I think the 37 was the direct one and the 38 was the Dunham one but don't quote me on that.
- 36/37 Manchester Piccadilly to Warrington via Altrincham and Little Bollington: most journeys were curtailed to start at Altrincham before the demise of NWRCC, but still runs as Warrington route X5 between Altrincham and Warrington and now extended to the Airport. The route was suspended entirely for a period and only revived recently with closure of the alternative route via Dunham Massey to large buses.
When A&D merged with Thames Valley to become Alder Valley, a lot of route numbers were repeated across the company, so in 1974 it was decided that the Aldershot side would be entirely remembered. They were mostly increased in digits by 200, but when MAP was introduced the 202 and 203 were renumbered as the 442 and 443. I think it may have been closer to deregulation when the 422/22 numbers came around, presumably as Alder Valley South registered a number of existing routes to become commercial.Interesting: I don't remember the 202 or 203; "in my day" (late NBC/early privatisation Alder Valley) the 202 was Alton-Petersfield via Selborne and the 203 was the Alton town service. In general, the routes in the range 200-216 were centred on Alton, aside from the 200 Basingstoke-Camberley (which was also operated by Alton garage).
The Aldershot-Farnborough-Camberley axis was the 22/422 every 20 mins: the 22 terminating at Yateley (which then became the "modern" 1 as you say) and the 422 extending every two hours to Reading. I didn't travel on, or even observe, this route until 1987, so not sure what it was in the years immediately preceding deregulation. I'd hazard a guess at all journeys being numbered 422, Reading or not, as sub-100 numbers only really came back post-deregulation.
As you remember, it was the 38 that went via Dunham, which with the 37 gave a bus every half hour or so between Warrington and Altrincham. That carried on under North Western, Arriva, Warrington BT and Warrington Coachways. Arriva gave up and Warrington BT extended the 5 to Altrincham competing with Warrington Coachways on the 38 route. When Warrington Coachways ended, the 37 was replaced by a 35 with the whole thing run by Warrington BT.There was definitely a 37, operated variously by the "new" NWRCC or Warrington Transport, as late as the mid-to-late 90s, from Altrincham to Warrington only. Don't think there was a 36, but there was also a 38. One went via Dunham and the other went direct via the A56, I think the 37 was the direct one and the 38 was the Dunham one but don't quote me on that.
And in the late 80s, the L1 was renumbered X1 and for a while ran Wrexham - Chester - Llandudno - Bangor - Carenarfon - Porthmadog, with an alternate X4 which after Bangor went to Holyhead. They also tried an X5 which went past Chester to Manchester Airport. None very succesful and it was eventually cut back to its original route and shortened before eventually ending mid 90s.At one time there was the L1 Chester to Caernarvon. Now multiple splits. Caernarvon to Llandudno, Llandudno to Rhyl, and the Rhyl Chester split as mentioned. In parallel to the L1 was the A1/A2 Caernarvon to Chester.
Round about 1968 (I'm away from home, so can't check sources) the hourly YWD 2 was combined with the hourly Hebble 2 (Halifax-Denholme-Bingley, which for much of the day just ran as a Cullingworth-Bingley shuttle, connecting with the YWD service) as 2/2A Ossett-Dewsbury-brighouse-Halifax-Denholme-Keighley/Bingley on alternate hours. The services were split at Halifax in the 1971 changes surrounding the dismemberment of Hebble. Halifax-Keighley/Bingley became Halifax JOC 2/1, whilst Ossett-Halifax became YWD 2. There was also YWD/West Riding 3 Wakefield-Ossett-Dewsbury-Brighouse-Hipperholme-Queensbury-Denholme-Cullingworth that at the same time was split at Brighouse, with a shortened Brighouse-Queensbury service becoming YWD 35 (hopelessly uneconomic, but presumably maintained to keep the rights to the lucrative Brighouse/Hipperholme/Shelf-Queensbury schools traffic) and the Wakefield-Brighouse section joined with YWD's Brighouse-Elland-Upper Edge operations as 79(?), with Yorkshire Traction and Halifax JOC replacing West Riding as joint operators. Under West Yorkshire PTE the 79 was diverted at Brighouse to take over the 35 (or 547 has it had become under WYPTE) - WYPTE as successors to Halifax JOC dropping out - whilst the 2 was diverted between Brighouse and Halifax to run via Elland, becoming 278, with Yorkshire Traction dropping out in favour of West Riding.Used to be a Yorkshire Woollen service 2 Ossett-Dewsbury-Brighouse-Halifax-Denholme-Keighley. It was running in 1966. Now there is a Halifax - Keighley 502 run by Transdev Team Pennine.
When I rode the 29A going to a church in Coalville on Sundays, I remember the 29/A was split at Coalville, with onward journeys continuing to Burton running as the 9/9A/9E.Arriva Midlands East 29/29A used to run from Burton-Leicester. It now only runs as far as Swadlincote and some journeys I believe split at Coalville.
I used to live in North London. I can remember route 2 that ran from North Finchley to Crystal Palace. The 84 from Arnos Grove to St Albans and the 279 from Waltham Abbey to Smithfield Market. There were probably others including the 29 that ran to Victoria but I'm not sure from where.
There were some extremely long Green Line routes (bearing in mind that many of them traversed London and went through its busiest districts). The 715 was certainly one of them. I used to see coaches on that route at Finsbury Park and Manor House. I recall writing to London Transport asking which was the longest Green Line route (they had a "Public Relations Office" at 55 Broadway back then and the staff there were happy to respond to all manner of odd enquiries). They kindly sent me a list of the top ten longest routes (which I have lost) but I recall the 715 came in at a little shy of 60 miles. The winner, however, was the 713 which ran for 66 miles from Dorking via Epsom, Clapham, Victoria, Hyde Park Corner, Baker Street then out via Hendon, Elstree, St. Albans all the way to Dunstable. I cannot imagine how long such a journey would take today!Mustn't forget the Green Line coaches. The 715 springs to mind Hertford to Guildford.
Actually, the 8 ran the whole length including New Oxford Street in both directions.I think I'm right in saying that at that time the 73 was the only route to run the full length of Oxford Street.
In the 1960s the 29 ran from Victoria to South Mimms in Hertfordshire, with a peak hour extension to Borehamwood. Today it runs from Trafalgar Square to Wood Green.
To add another from that area, 19 Bath to Bristol Parkway used to go to Cribbs Causeway until recentlyAnd a raft of West Country ones based on retaining the same number...
184 Bath to Frome - now Midsomer Norton to Frome
162 Wells to Frome - now Shepton Mallet to Frome
21 Taunton to Burnham on Sea - for a brief period, it was extended to Weston super Mare but thankfully unpicked
D1 Bath to Salisbury - now Bath to Warminster
271-3 Bath to Urchfont/Easterton - now Bath to Devizes
87 Salisbury to Andover - now curtailed at Middle Wallop
X3 Salisbury to Poole - now curtailed at Bournemouth
X53 Bournemouth to Exeter - now only runs Weymouth to Axminster
155 Barnstaple to Exeter - now runs only Barnstaple to South Molton
398 Tiverton to Minehead - now runs Tiverton to Dulverton
99 Taunton to Yeovil - now runs as First 99 Taunton to Chard, and SWC 96 Chard to Yeovil
635 Chippenham to Marshfield used to run through to Bristol. It was then separated into two halves (both numbered 635 but tendered by different local authorities) and operated by First (Bristol to Marshfield) and Faresaver. Faresaver then won the other half and it resumed as a through route, but later reverted to two halves with First regaining what was then the 35. 635 still runs as Chippenham to Marshfield but the 35 now only runs to Kingswood but is now run by Faresaver again!
There are countless examples I've missed, plus plenty of other long routes in the mists of time that have been dismembered and are now covered by an array of different services, all with different numbers
Sort of. IIRC the OK 700 didn't serve Durham city, operating direct from Framwellgate moor to Nevilles Cross. At that time, there was a Northern 724 From Newcastle Marlborough crescent to Bishop Auckland that did run via Durham city, but I think that one had an unusual routing Newcastle to Chester le Street, via Bensham? That version of the 724 died soon after dereg, not long afterwards the 700 became the 724 and diverted via Durham city initially evenings only. The 700 was one of the last conductor crewed services in the northeast, along with the 441 Ashington Blyth and the 263 Middlesbrough Eston Redcar services (unless you count the odd routemaster operated 21 a few years ago).note that GNE X21 is actually a continuation of former OK 700 that latterly reused the 724 number
The X6 briefly continued from Leicester to Notttinghamevery couple of hours, though I think for less that a year (a corridor that has been tried a few time by different companies, but difficult to compete with the train for those that want fast and frequent (50 on a typical day) and National Express for those who want cheap (there's 27 of those next Tuesday) and not many potential passengers on the way.Stagecoach Midlands -
X4 used to be Milton Keynes-Peterborough, now Northampton-Peterborough.
X6 Milton Keynes-Leicester, now Northampton-Leicester
(The MK section was replaced by X6, originally at the same half hourly frequency but now operating once an hour)
X46 Northampton-Thrapston, now Northampton-Rushden
D1 Northampton-Rugby, recently split at Daventry
96 Bedford-Birmingham, split many times and now Northampton-Rugby
Do you mean the X7?Stagecoach Midlands -
Ah thanks! The dear old No 8. I'd forgotten that.Actually, the 8 ran the whole length including New Oxford Street in both directions.
I think you're probably right. Borehamwood was a bit out of my way and I never saw a 29 headed there. Looking at some old timetables, it seems the number of runs was very limited and those there were seemed to start from Turnpike Lane.I don't think the Borehamwood buses ever came near to Central London, unlike South Mimms buses. The 134 also ran from Pimlico, Dolphin Square to Potters Bar, with a through service working all day every day throughout the route.
I think you're probably right (again!). Looking again at timetables, the 133 took 2 hours to complete its trip. I thought the Sunday No 9 (Mortlake to Becontree) would be longer, but the journey time is only 1h 45mins. Not very scientific I know, but provides a guide.I seem to remember the longest bus route in the 1960s though was the Sunday 133 South Croydon Garage to Hendon Central Station,
Yes, the X7. My apologies. I believe it started with B10Ms in the early 2000's.Do you mean the X7?
