Trivia: Intermediate stations with frequent crew changes
GordonT
26 May 2018
I'm particularly thinking of Newcastle and Preston where severe delays to Anglo-Scottish services in one direction through these stations are likely to impact on trains in the opposite direction awaiting crews from the severely delayed services. Any other examples including shorter distance services? I suspect Finsbury Park may be an example with reference to Thameslink services.
godfreycomplex
23 Jun 2016
Fratton, Staines, Woking, Guildford, Basingrad, Salisbury, Bournemouth.
Some of these have multiple platforms so service disruptions can be mitigated if a train’s waiting crew. Some don’t. Staines is a particular headache.
Further afield you’ve got Colchester, Garscadden, Manchester Oxford Road, Northampton, Selhurst, Norwood Junction, Perth, Derby and Bishop’s Stortford
clagmonster
8 Jun 2005
There will be absolutely loads.
Manchester Oxford Road is an interesting one worth pointing out as there is no train crew depot there. It is used instead of Piccadilly so that there are routes around trains awaiting a fresh crew.
D6130
12 Jan 2021
West Yorkshire/Tuscany
Skipton....for Leeds-Carlisle/Lancaster/Morecambe services.
Leeds, Manchester Victoria and Wigan Wallgate....for lots of Northern services.
Bathgate and Perth for Scotrail services.
wobman
2 Jan 2011
Here are a few TFW intermediate Crew changes Llandudno junction/ Wrexham (no train crew depot) / Shrewsbury / Crewe / Chester to name just isn't a few
Flange Squeal
17 Jul 2012
Farnham and Aldershot both have very regular crew changes throughout the day. Farnham has a traincrew depot but only up and down platforms - to clear the line stuff can go into the depot, but subject to the crew being from a depot that signs it. Aldershot just has a messroom for breaks, but a loop on the down can facilitate ‘getting around’ something in the down direction only.
brick60000
18 Apr 2013
Reading and Birmingham New Street for XC
Freight wise, the Carlisle yards.
Quite a lot for CrossCountry, due to the long distance nature of the routes.
Others include:
On the Anglo Scots - Newcastle, Leeds, Derby, New Street, Bristol
On the 170s - New Street, Cambridge, Leicester
306024
23 Jan 2013
East Anglia
There are lots. The key is to have a diagramming strategy that minimises the risk. No intermediate relief is a good starting point but clearly impractical for longer distance services. Relief where there is a traincrew depot located is next best, gives you more chance of recovering the service. Relief where a train can be removed from the running lines easily or not block up platforms is preferable. Keeping the crew with the train as much as possible on short suburban workings helps too.
Birkenhead Central - Merseyrail crews always seem to change there.
But you'd hardly know normally, the stop is usually brief.
When turnround times at the extremities of the Wirral network are extended for any reason, there will always be a long wait at Birkenhead Central (and sometimes at Rock Ferry), while the clockface timetable onwards through the loop catches up.
Taunton
1 Aug 2013
A curious hangover from long ago. Birkenhead Central was the operating base for the old Mersey Railway, and likewise Birkenhead North for the Wirral Railway. Although merged together into one electric system over 80 years ago, the old mid-route bases persist. I don't know what the diagrams are like nowadays, but some years ago it was still the way that Central crews mixed in on the New Brighton line, while West Kirby was the province of North crews - which reflected the way the initial Wirral electrics were shared between the two onetime companies.
skyhigh
14 Sep 2014
Sheffield, Harrogate and Selby too. There's probably hundreds across the network.
Djgr
30 Jul 2018
And what a nightmare this turns out to be
Tomnick
10 Jun 2005
Nottingham's a good example not only for passenger trains, but also for freight. On several occasions, a freight train has turned up from the east with no driver to work it forward, and with the inward driver not signing anywhere west of the station - if they're allowed into a platform, they invariably cripple the east end of the station as they're too long to clear the various connections, but even if they're held back at the last signal, anything else following them will be stuck for the duration too.
Bristol
Haywards Heath used to be, because of the number of trains splitting/attaching there. Not sure if that still happens.
