[Trivia] Largest UK railway station to have a subway and/or footbridge but no lifts?
infobleep
27 Feb 2011
I could find this question before but apologies if it's been answered.
What is the largest UK railway station to have a subway and/or footbridge connecting one or more platforms but no lifts?
Or to put it more simply, which is the largest station not to have level access to all platforms. I believe level access doesn't include ramps between platforms.
greaterwest
23 Nov 2014
London Paddington has accessible platforms but also has a footbridge with only a lift down to platform 1. Does that count?
For non-London termini, Guildford might be a contender with both a footbridge and a subway but no lifts?
PTR 444
22 Aug 2019
Wimborne
I was about to say Bournemouth, but if I’ve understood the question correctly that doesn’t count as its subway has ramps providing level access.
Magdalia
1 Jan 2022
The Fens
The National Rail website says this about Guildford:
There is level access to the booking hall and all platforms from the main entrance in Walnut Tree Close. There is no step free access from the Guildford Park Road entrance.
There is step free access to and interchange between all platforms via steep ramps. A staff operated powered wheelchair is available for customers. Please speak to a member of staff or our Assisted Travel team.
Luton only has a lift to platform 5.
This is a bit of a moan of mine. I don't regard ramps as level access. I have a dodgy heart and walking up ramps is just as difficult for me as walking up stairs. Two stations with subway ramps that I struggle with are Ely and Barnham.
Lampshade
3 Sep 2009
South London
I know there's one with no accessible access to one platform so you need to one stop in the other direction and change, but I can't remember which one exactly - somewhere in Southeastern land maybe.
Trainguy34
29 Apr 2023
Kent
I think thats Aylesham, most definitely in Southeastern Land
plugwash
29 May 2015
These are not the same thing.
For example Manchester oxford Road has lifts to take you from platforms 4/5 (where the entrance is) to platforms 2/3, but only has stairs to take you to platform 1.
infobleep
27 Feb 2011
I'm not sure if level access is the right term. When looking up the Croydon redevelopment in 2011, one Web site referred to the station redevelopment as having level access but East Croydon had ramps anyway.
So maybe ramps count as level access.
I hadn't thought of stations where only some platforms have lifts.
plugwash
29 May 2015
I suspect the answer to the question of busiest station without step-free access on national rail is moorgate.
bishdunster
9 Oct 2012
Dunster
Are you certain? Bournemouth certainly had lifts on P2 and P3 back in the 1970s when i worked there.
DelW
15 Jan 2015
"There is level access to the booking hall and all platforms from the main entrance in Walnut Tree Close. There is no step free access from the Guildford Park Road entrance.
There is step free access to and interchange between all platforms via steep ramps."
That NR statement is contradictory.
There is level access from the main entrance only to platforms 1 and 2.
To get from there to platforms 3 - 8 means using the very same ramps referred to as "steep" in the second paragraph.
duffield
31 Jul 2013
East Midlands
As discussed on other threads, Bletchley does not have lifts from the footbridge to platform 6, but does have them to all the other platforms.
Rather depends on definition of largest station, eg Esher only uses 2 platforms, but has 2 more (disused) platforms with tracks and 3 closed race platforms.
Yeovil Junction is another big station without lifts, but again part of it is disused
plugwash
29 May 2015
The Elizabeth line has changed that, albeit only to those platforms
I guess that comes down to how you define "station". The crossrail platforms are connected to moorgate station but are nominally part of Liverpool Street.
DM352
9 Oct 2019
Matlock
Similar to Esher, was thinking Skipton but they since closed access to their disused platforms and not been there in 25 years!
DanNCL
17 Jul 2017
County Durham
Depends on how steep they are. To give two contrasting examples in the North East, the ramps at the fairly new Horden station are considered to provide level access, however the ramps at Northallerton were considered to be too steep and have now been replaced by lifts to each platform and new stairs where the old ramps were.
BRX
20 Oct 2008
Tulse Hill and Peckham Rye both have 4 platforms and no level access to any of them.
14 Mar 2021
Argyle Street station on the Glasgow Central low level line has escalators but no lifts. It must be one of the most recently built stations without level access.
It could be argued that Glasgow Central Low Level is a suitable alternative station, being nearby on the same street. However, Argyle Street is popular with shoppers, and so people with prams and strollers use the escalators rather than travel through to Glasgow Central. I have seen a staff member rush out of the ticket office to assist someone to hold their pram or stroller on the escalator.
Ken H
11 Nov 2018
N Yorks
Settle has no step free access to the northbound platform. OK its not a large station but can be very busy at certain times.
Skipton and Hellifield both have ramps only. Hellifield ones are quite steep.
CyrusWuff
20 May 2013
Though for LU operational purposes, they fall under Moorgate, just to confuse matters!
Haywain
3 Feb 2013
And that is outside the station as part of the footbridge to get from one side of town to the other. There is level access from street level to platform 5 but no level access to the other four platforms. However, the refreshment/waiting rooms on the island platforms do have ramps!
The exile
31 Mar 2010
Somerset
I suspect there are loads of those.
