Trivia- most circuitous route between closest stations.
vidal
23 Feb 2017
Bolton
Let's exclude the London terminii.Wigan Wallgate to Wigan North Western via normal timetabled services? Any others that immediately jump out?
James
WizCastro197
12 May 2022
Reigate
James
What do you mean by circuitous?
I was going to say Streatham stations but I am not sure what your criteria are.
Mcr Warrior
8 Jan 2009
St Albans to St Albans Abbey. Maybe 35 miles by rail? Just over a mile on foot. Is that what you were after?
vidal
23 Feb 2017
Bolton
The two Wigan stations are visible from each other and are only a few tens of metres apart. There's no direct service so how would I get from station to station just using the train.
SD.
Purple Train
16 Jul 2022
Darkest Commuterland
SD.
With your given example, it would be an hour and a quarter changing at Daisy Hill.
Catford to Catford Bridge might also be a contender - not the longest journey (40 minutes roughly from memory) but the stations are so close to each other that the ratio is probably bigger.
Mcr Warrior
8 Jan 2009
Change at Ince?
PGAT
13 Apr 2022
Selhurst
Well Streatham and Streatham Common are direct, and Streatham Hill is only 1/2 changes (1 for changing at Balham for Streatham Common, and possibly 1 if the parliamentary service comes back for Streatham)
The two Windsor stations are going to be difficult to beat. Just 350m apart but it would take a journey of 37.5 miles to get between the two via the absolute shortest rail route - via Brentford, Acton Central and Acton Main Line. However, this route has no passenger service over two parts of it (Brentford to South Acton and Acton Central to Main Line). The shortest route with a passenger service would be 51.5 miles via Reading. That's a ratio of 1:237.
CaptainHaddock
10 Feb 2011
New Mills Central to New Mills Newtown.
BRFares offers a single fare of £16.80, changing at Manchester Piccadilly and taking around 1 hour 30 minutes. You can walk between the two stations in ten!
Mcr Warrior
8 Jan 2009
The trains to Wigan North Western run nonstop from Daisy Hill (skipping the interchange station of Hindley & Ince)
Believe the 0833, 1433 (SX) and 1956 weekday departures from Ince all terminate at Wigan North Western. Is that no longer the case?
duncanp
16 Aug 2012
Hertford North to Hertford East
On the tube : North Ealing to West Acton
duncanp
16 Aug 2012
Harringay Green Lanes (GOBLIN) to Harringay
Leytobstone High Road (GOBLIN) to Leytonstone (Central Line)
Kentish Town to Kentish Town West
Camden Town to Camden High Road
Ken H
11 Nov 2018
N Yorks
Bradford stations. To leeds and back. Not too far.
Does a case like liverpool Lime St and Liverpool Central count. Is lime street 2 stations or one? Same question for Glasgow.
In the old days it would have been different. Liv Exchange to Central????
MadMac
13 Jun 2008
Moorpark, CA
Uddingston to Newton. Only way between the two is to go all the way round via Hamilton. Newton is where you would change for trains to Cathcart Circle stations and King’s Park for Hampden Park.
bunnahabhain
8 Jun 2005
Never really understood the point of these questions. It's more interesting surely to compare routes where the rail journey between locations is extraordinarily longer than by other methods of transport. Example, Skegness to King's Lynn. 55 by road, 132 by rail, even shorter by air.
61653 HTAFC
18 Dec 2012
Another planet...
Inspired by discussions elsewhere, Bradford Interchange to Bradford Forster Square is fairly simple changing at Leeds... but for a bit of extra fun, avoiding Leeds would require changing at Preston, Lancaster and Bingley (or Shipley, but Bingley would be a same-platform change).
Master29
19 Feb 2015
Surely though by this logic, air has got to win each time, unless both Kings Lynn and Skegness have international airports which I don't recall.
Peter0124
20 Nov 2016
You could change at Cambuslang. Admittedly the connections can be terrible.
Hopefully there will be direct services between the two in the near future:
ANDREW_D_WEBB
21 Aug 2013
Several on the Tube.
Warren Street to Euston Square
Euston Square to Euston
Bayswater to Queensway
Hammersmith (Piccadilly and District) to Hammersmith (Circle and Hammersmith & City)
Epping to Harlow, the latter not on the Tube.
Away from the Tube, Bourne End to High Wycombe is much quicker by bus (and Plusbus is valid).
Mcr Warrior
8 Jan 2009
About half a mile to walk, about 27-28 by train.
Can this not (in theory) be done by changing at both Chinley and Hazel Grove? Something like 18 miles then.
Howardh
17 May 2011
I didn't think this was possible, but a ticket is available between Blackpool North and South, via Kirkham. Admits it's a long walk between them (Mile?? More??) but still walkable and a single can be anything between £8.10 and £26.60.
£26.60 for goodness sakes....that is the Lancashire Day Ranger but there's no alternative save for the odd service which charges the lower fare (eg 1755).
